Ga door naar hoofdinhoud
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Volume rocker problem dropped ipad
I dropped my ipad 2wifi+3g which landed on the volume rocker. Consequences are that volume is continuosly at maximum level and have volume "icon" permanently at the centre of the screen.
Can anybody help me? I appreciate your help. Thanks!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sadly, the only fix for this is to remove the glass and probably bend the frame back out. Most likely, your volume key is pushed in by the damage of the drop. Best of luck with that friend.
Was dit antwoord nuttig?
Voeg je antwoord toe
Paul Balassiano zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 575
