Ga door naar hoofdinhoud
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Vragen Bekijk alle
No input/output Audio Devices
MacBook 13" Unibody (Model A1342) Mid 2010 , Mac OS X (10.6.8)
The sound suddenly stopped. On System Preferences, on Audio, it shows the sound as muted and doesn't allow me to unmute it. System Profiler shows Audio (Built-in): Intel High Definition Audio: Audio ID - 0, no input/output Audio Devices. I fixed the hard drive access permission , did the reset for both pram and smc several times and finally installed a clear copy of mac OS after deleting the HD, but unfortunately ended with no success. Do you think it is a hardware related problem? How do I fix this?
 Thank you in advance.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hello Mary, Apparently Apple has a problem with the 10.6.8 update having to do with audio. I am including a link to a discussion on the subject. Hope this helps you.
http://support.apple.com/kb/HT4561
Including a link to the support page also.
http://support.apple.com/kb/index?page=s...
Was dit antwoord nuttig?
Score 2
Thank you for your reply. I installed the update and restarted the computer but with no luck. The advanced hardware test i run shows no errors!!!Do you have other suggestions? thanks
Voeg je antwoord toe
Mary zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,927
