Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
iPhone 4s headphone jack unrecognized
hi there, i have a sprint iphone 4s i did the tear down and replaced a broken screen and thought everything was fine but my audio jack is simply not working. It plays music out of speakers ONLY it dont matter how many times i connect the headphone jack it dont recognize the audio jack. Im wondering did i leave something disconnected? did i miss anything?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you left something disconnected then your volume buttons and your vibrate switch would not work as well, as they are all on the same ribbon. If those functions still work, you may have accidentally torn the ribbon leading to the headphone jack. In that case, you will need to replace the headphone jack/volume/vibrate ribbon.
Was dit antwoord nuttig?
Voeg je antwoord toe
Hector Rodriguez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 544
