Ga door naar hoofdinhoud
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Vragen Bekijk alle
Vraag afgerond
Can I replace dead superdrive with a SSD hardrive?
I have a Model A1224 / Mid 2007 / 2 GHz Core 2 Duo processor / 4 Gigs Ram ver 10.6.8
Can I replace my dead optical superdrive with an SSD drive?
What kind of enclosure do I need and can I use the
existing cables in my iMAC to achieve this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here is the guide to replace the optical drive with a hdd or ssd.
Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive
Your iMac will need a ATAPI enclosure like this one:
http://www.pro-battery.com/battery-detai...
If you take that info and look for the equivalent on iFixit this is what you will find:
[gekoppeld product ontbreekt of is uitgeschakeld: IF107-079]
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thank you Jay for your info
Can you tell me what kind of enclosure/caddy I need and can I use the
door
door
I do appreciate the time you took to answer my question.
But your link says it's for a mac Mini not a Mid 2007 / 2 GHz Core 2 Duo processor desktop. I'm still stuck with no answer.
door
I just edited my answer and added links to the proper enclosure. I did a quick search on your iMac and found that the one in the guide will not work as its SATA and not ATAPI.
door
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 9,320
