Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Vragen Bekijk alle
Vraag afgerond
Replaced motor phone not vibrating
recently my phone stopped vibrating, after replacing vibrating motor it worked for about a month and stopped again. i ordered another motor and replaced. phone still doesn't vibrate. thinking it's a bad part i ordered another one but it didn't work either.
got a friend with iphone 4 and used his motor in my phone, no luck. put the motor back into his phone and it works fine.
what else could it be that prevents my phone from vibrating?
please help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Possibly faulty Headphone Jack Cable. When you flip the Mute/Vibrate Switch do you get screen response?
Was dit antwoord nuttig?
3 opmerkingen:
Sometimes the mute toggle can still work but the 2 contact pads for the vibrator don't work. Id recommend replacing the headphone jack aswell.
door
yes, when i flip Mute/Vibrate i do see screen response.
door
Then I would go with ReekoB recomendation and replace the Headphone Jack Flex cable. He says even with screen response the Flex Contacts may not be providing the necessary power.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 441
