Ga door naar hoofdinhoud
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
need help Identifying my iPod
I have a 30gb 4th gen iPod model number A1099. Id like to know if its a photo or regualr iPod.
Is dit een goede vraag?
Score 1
1 Opmerking
Out of curiosity, are you unable to turn it on? The easiest way to ID it is to check the screen. Additionally, the color LCD is more of a black color when off, compared to the gray, flat look of a monochrome LCD.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You have an iPod Photo. For future reference, we have a nifty little guide that can help you ID your iPod.
Was dit antwoord nuttig?
Score 2
I believe your 30GB model is an iPod Photo. you can look up the model number on sites like this one
Also, according to wikipedia, the "regular" 4th gen iPod only came in 20GB and 40GB versions, so your 30GB one must be the "Photo" version
As the others have said, you have a photo, but a general fact you should know is it's not really necessary to know, almost all the parts are interchangeable between Photo and 4th gen.
1 Opmerking:
It's deceptively trickier than appears. The moving of the display connector on the logic board makes the display, logic board, and front panel not directly interchangeable.
door
Voeg je antwoord toe
Robert zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 2,454
