Ga door naar hoofdinhoud
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 Vragen Bekijk alle
My Phone Keeps turning off and then turning itself back on?
When I turn on my Droid RAZR and it does its power up, I wait for my service to come on. Before the service gets turned on, the phone restarts itself every time. It continues to do this over and over and over until it runs out of battery. I've tried hooking it up to chargers and hooking it up to a computer. It continues to do the same thing. I tried to restart the phone manually, but this still hasn't fixed the problem. Do I need to buy a new phone?
Is dit een goede vraag?
Score 120
44 opmerkingen
I have that very same problem: my phone doesn't power reset while in Fastboot mode, but I have tried 10 or so different ROMs without success... I have been careful about wiping internal memory before and after each flash, with no success... what would be the next thing to troubleshoot?
door
I need help, my phone is turning off at random times and it's annoying and bad! What if I need help and can't call 911 or can't call my parents if it's an emergency? I need help and quick is there an easy way I can fix it? It is an iPhone 3GS - stressed out teen
door
I need a easy simplified way to do this.. Any help is appreciated
door
i dont know how to fix my phone it always goes off and on i will give 150$ if my phone is fix by your inscruction's
door
if u dont have the iphone 6 try this shut ur phone down by holding the turn on button and the place where u press with ur thumb then after u shut it press the upper volume button for two minutes
door
39 commentaren meer tonen
Voeg een opmerking toe
31 Antwoorden
Gekozen oplossing
Motorola phones can do this when they have a problem with their bootloader or software files.
It should be possible to load into FastBoot mode to re-flash the phone's ROM and hopefully resolve the issue.
This is a fairly in-depth process. Before getting into it, make sure the phone will actually boot and run in FastBoot. To do this, turn the phone off, then hold the Vol+, Vol- and power buttons all at the same time until a white screen appears, then release. This should bring you to FastBoot. If the phone doesn't reset here, then I would suggest proceeding with flashing a ROM. For this, I direct you to an existing Motorola Droid RAZR FastBoot guide.
I hope this works for you, I've used this method on other Motorola phones such as the Atrix 2 and the Bionic.
If nothing else, it's easier to try this than to replace the phone.
Was dit antwoord nuttig?
Score 22
13 opmerkingen:
It shows 3 option.. Which one should I click first?
door
what for a windows phone?
door
Thank you SO much! You saved my phone & my sanity!
door
not working :(
door
None of that wont work, take my advice, get a new phone because you been hacked, basically you already been spied on, they can installed apps without you knowing, add unusual files in your storage which is viruses, if you have a two way camera they probably watching you like a perv, they can reset your phone anytime unless your on wifi or on data network, pretty much they are cyber bullying you which I called it but they is might be a solution that might help, go to settings then apps then all apps and start disable all the apps that are unusual, i had the problem in about few min. ago i think its working fine so far if not ill let yall know
door
8 commentaren meer tonen
get a string or some wire and tie your phone up and hang it by a tree branch then shot your phone with a glock 18, see your aiming results and then get a new phone that simple. xD lls lmao lmfao ctfu.
Score 10
6 opmerkingen:
I have a Glock 17, do I need to spend the $600 to upgrade my Glock before I can shook my fkng phone?
door
Also u can use a bazooka
my phone its working lol
door
hey their can help me to my mother phone . its always turn off and turn on .. i dont know what happen . .
door
I think I'll borrow my friends HK 91 to satisfy my frustration! If that doesn't work, I give up!
door
or perhaps a laws rocket....
door
1 commentaar meer tonen
Mine was turning itself on and off by itself today. When I finally got it to turn off and stay off I opened the cover for the sim card on the side of the Razr and the sim card was loose. I pushed it back in until it locked and problem solved. Everything is working fine again.
Just make sure you don't take the sim card out while the phone is on as this may damage the sim card and/or the phone itself.
10/31/14
Score 7
2 opmerkingen:
tried this and before I did this it it would turn off every few seconds and now its been a couple minutes. I'll update if it stops working soon but so far thank you so much Wayne!!!!
door
can anyone help me out here i bought a phone htc window 8x it just stop work just like that just turn off so i pull it down unplug the battery and plug on again and it power back up but when to pick up the service it shut right back down repeatedly can someone tell me what to do ?
door
My phone goose off and on by itself. It can do that for the whole day or even two. Then it works again for a while. What do I do? Its a Motorola droid RAZR maxx
Score 5
1 Opmerking:
I have this exact same phone mines doing it to :(
door
I kept trying to turn it on but it keeps turning off
Score 4
4 opmerkingen:
my phone doing the same thing but mine is a cheap government phone from verizon...I need to make calls and waiting for a call back to work..HELP!!!!!
door
Hold down the vol+ key.the menu key & the power key all at the same time.then scroll down via the vol key to clear catch or factory reset then push power key to activate..your phone will be like its btand new as you would have lost all previous information so store this before attempting .good luck
door
Thx alote fatcat ,u helped me ^^ :*
door
I have that problem with my tablet! It'll stay on for a bit, then turn of, turn on, turn off, and it keeps repeating that all the time!
door
Your software had gone bad. Get it fixed from service center
Score 3
2 opmerkingen:
Mine is doing the same thing, will I have to pay to get it fixed when it's not my fault? Also, can I upgrade when it's doing that or do I have to get it fixed first?
door
Yes thats true
door
I appreciate there are other reasons why a phone turns itself on and off. Mine was doing this, I took out the SD card and it was fine. Usually, when you ask that the SD card be the default storage, the phone turns itself off to reset. I think my SD card corrupted that's why it was turning my phone on and off.
Score 3
2 opmerkingen:
I would have never guessed,Thanks alot!!!
door
Hi Megstermay thanks for your answer, i was backing up my data and the phone started to turn it off and on.. I took the sd card off and now it's ok...so on my way to buy another sd card cross fingers it will solve all problems, thank s you
door
I dropped my phone way too many times and now all it does is turn itself on and off never getting to the start screen. and it only does it if its plugged in. Its just off, off the charger. took out the battery to see if that's the problem. Nope. Tried the fast boot. It keeps the phone from turning on again but a white screen never shows up. Its an alcatel touch android not a motorola though. My boyfriend took the back off with his handy dandy tool kit, and there seems to be nothing wrong with the circuits. Nothing seems obviously out of place, loose or broken anyway.
Any more great ideas?
Score 2
2 opmerkingen:
ok, found out it was bc the battery wasn't touching the prongs, a plastic piece had fallen loose. I wedged it back under the battery, and it works just fine.
door
Noice thats very noice
door
What is wrong
Score 1
1 Opmerking:
My Motorola g6 es keeps switching itself on only on all the time and its brand new I've tried knocking it off and it still doing the same
door
if u wanna know what's right for our for phone its easy just go to a shop where they fix phone's and they will help u fix it
Score 1
1 Opmerking:
the problem its that they do that but i lose to much time when the problem its always the same
door
My Phone Keeps Turning Off then One By its self
Score 1
Have the same problem here!..
When i turn on my phone its restart...
Plsss... Help me...
I dont want to lose my phone... :"(
Plss help!!..
Score 1
my phone did it soon I just got now
My phone has been doing the same thing. I was going onto my online banking when it foreclosed on me going back to google search. I turned my phone off to resest it and turned it back on . Now it goes on and off with the annoying dinging blue intel screen. Do I need a new phone or throw it against the wall? I'm at that point.
3 opmerkingen:
mine i was downloading programs and uninstall other programs and the phone turned off that happened three times and i buyed the phone with that problem
door
same here i was listening to music then it went to some green bot and then started turning off and on and been doing it every since that was like at 10:00 its 5:05 its died and im charging it and now its a android back to metro pc im about to break my phone helppppp pleaseeeeeee
door
It's stupid for a iPhone to turn back off and on
door
I recently dropped my phone about 2-3 times and now, it keeps going on and off. When i charge it, the battery is at say 80 percent and when it starts going off and on as usual, it boils down to say 40 percent within 2mins.
Any suggestions? perhaps ? I'll be glad to hear.
Thanks. P.S it's an LG Flex.
1 Opmerking:
You need a new battery it's because you have done something to it you can easily get one from eBay or from a phone shop
door
I also had this problem. I was instructed to shut down my droid max while it was cycled on ipulled my vol. Switch disloged my sims card waited a ten count . reinserted the sims and harded booted after that exercise. After it cycled back on the headache disappeared so far. ( four weeks ago) . no logical reason but it has. Try it it couldn't hurt. All the best! LHH
my phone is doing something just a little different. it turns on just fine but then it just starts to cycle bringing up random $@$* like my camera then a video then maybe my gallery. but nothing stays on long enough no matter what i touch. i cant do anything but shut it down if im lucky enough to hit off as it passes me up. so i usually just pull the battery. please help
1 Opmerking:
Did you change laucher on your phone bye any chance?go back to your original laucher
door
Yes my phone also shuts off and turn on automatically
I am going to change the phone for this cause
Its perfect phone but what can i do
Using droid razr m
I have a SAMSUNG GALAXY NOTE 5 AND FOR THE PAST WEEK THIS PHONE HAS BEEN CUTTING OFF BY ITSELF THEN COMING BACK ON. I DONT KNOW WHAT IS WRONG WITH IT . SHOULD I TAKE IT BACK 2 SPRINT ?
A charging issue can make a device turn on and off. A bad battery, a bad charger, a weak charger, or more commonly, bent pins in the charging port.
I don't think this will apply to everybody, but I have a spare battery for my galaxy s5 and have found it only lasts so long these days until it starts turning off and on constantly. Recharging it in my battery charger brings it back for a while, so I think it might be dying, even though I don't think I have had it that long. My other battery that came with the phone works fine.
I have a problem like this but it fixed when I reset my phone ( factory reset).
I have a problem, my phone restarts it self when i turn on wifi/data, if I disable my wifi or data it works perfect I dont know what to do any time wifi on it starts till battery down. Any body tell me what to do.....?
My phone scream turns of randomly like if I'm not touching the screan for example typing or just touching the screan, if I just leave it on it will turn off in 2 seconds. Like when I watch my youtube videos it turns the scream of or when I make music.ly it turns the screan off while I'm filming my music.ly what can I do pls help?
my phone keep cutting on and of constanly!!!!!!!!!!!!!
hi
my phone moto g 2 keeps restarting itself .it happens again and again after i changed my broken screen.pls help
1 Opmerking:
re flash your phone, it's firmware is broken
door
i have a zte phone that go off by itself and optimize on it's on i need a new phone can you help me
My phone keeps on doing the same thing and I don't have an SIM card
My phone keeps turning off by itself ND it stays off this happened twice but it came on again ND now thus time it just stayed off there is nothing wrong with it I checked everything ND I ever left it alone for a week ... I really don't want to lose everything on my phone.
Plsssss help me
It​ ​is​ ​a​ ​great​ ​article.​ ​You​ ​will​ ​surely​ ​like​ ​this​ ​also​ ​because​ ​it​ ​is​ ​a​ ​great​ ​stuff,​ ​yeah
it’s​ ​give​ ​us​ ​lots​ ​of​ ​interest​ ​and​ ​pleasure.​ ​Their​ ​opportunities​ ​are​ ​so​ ​fantastic​ ​and
working​ ​style​ ​so​ ​speedy.​ ​Thank​ ​you​ ​for​ ​sharing​ ​the​ ​nice​ ​article.
http://ssapptricks.com/bancolombia/
ACTUALLY, this PROBLEM has NOT been SOLVED. That said, I honestly don't believe it ever will be either. This random automatic "rebooting" issue plagues many, many cell phones. The reason your phone turns on and off is because it is "rebooting" itself after searching for and supposedly downloading an "automatic update" for it's software. Your phone will do this after it does an automatic update download from god only knows where. I often wonder if there is some sort of server somewhere that is actually downloading our "private" information from our cell phones. It wouldn't surprise me one bit if "big brother" government is spying on us in this fashion. There is NO privacy at all these days. Never will be if you use electronic devices. They keep records of everything we do. If you disagree, that's fine, but you are only kidding yourself. Anyhow, the underlying problem that I see is that most "updates" for cell phones that aren't relatively new are defunct, and do not actually even exist. For example, my phone hasn't actually downloaded and recorded an update since 2013, according to the information within my phone. Well guess what... it's 2018 now, 5 years since the last update "took" to my phone. Yet, for some reason, the cell phone still continues to "try" to update itself, landing in a continuous loop of unnecessary automatic rebooting. At any rate, if it is not the government spying on us, then the entire situation reeks of a defective software "glitch" or "bug", if you will. There are really no other feasible explanations for what is going on with EVERYONE'S phones. The cell phone companies and manufacturers have proven (by their lack of repair/remedy to said situations) that they just DO NOT CARE, and will NOT offer any solutions to said problems. It is what it is. You're screwed into buying a new phone if you can't get your phone to quit trying to "auto-update" itself. My Samsung Gusto3 acts this way every once in a while. Usually first thing in the morning, around 5 or 6 am. It just continuously acts like it's communicating with something, then reboots itself, over and over and over again until it will eventually drain the battery dead over the course of several hours! When I notice it doing this $@$*, I shut it off (if I can first, sometimes I can't), and take out the battery for a good 15 minutes or longer, if need be. Put it back it, turn phone on, and problem seems to go away for a good long while. (Sometimes weeks, sometimes only days.) Bottom line is that your phone is F*CKED, and there's NOTHING that we, the general public, can do about it. If it becomes too big of a problem for you, all I can suggest is that you get a new phone. Sadly, who knows how long your new phone will last before having the same issues. There's just no way to know. One thing's for certain, I wouldn't get the same make and model of phone. My best guess is that's exactly what the phone manufacturers and cell phone companies want you to do anyhow - buy a new phone. Remember, nothing lasts forever, and everything is designed to have a "useful life", AKA: Designed to FAIL. It's a sad world we live in... we have become slaves to our little electronic ball-and-chain devices that rob us blind, not just financially, but in many other ways.
Voeg je antwoord toe
richboy678 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 107
Altijd: 459,718
