Why won't it start?
My fa50 won't start. It gets good spark,gas,air,and air compression. Why won't it start?
Is dit een goede vraag?
the main jet needs to be cleaned in the carb .. take off the carb and clean it out
Was dit antwoord nuttig?
Sounds as if you are not getting fuel from the carburator into the cylinder correctly, if it were me, I would remove and then clean that carburator by use of some instructions from a repair manual.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 2,874
4 opmerkingen
What have you tried so far? Tried to squirt a bit of gas into the spark plug hole and try to start it, just to make sure it does get fuel?
door oldturkey03
yes but dies once gas burnt
door jwhiteboy68
jwhiteboy68, is this the same moped? Are you rodneylambert45? Just making sure we are dealing with the same issue here.
door oldturkey03
Here to, won't start normal ,does wel with startpilot at airfilter. When warm motor ,starts fine with kick only.
door Noel De Wulf
