Ga door naar hoofdinhoud
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
No Pass for Logon
Hi to all,
I have a iBook G4 that was given to us, and we do not have the name and password to access the machine. I dont know what version of Mac os it is ,and we dont have the person who owned it before us. ( What happened is my husband got a construction job to rebuilt a house, and this and another netbook was left behind) is how I got this machine.
Anyway not being a mac user for over 10 years I have forgotten if there is a work around to this to get it up and running (bypass login)
I know I can get a copy of the version I need for this thru Smalldog but would rather see if I can do it otherwise
Thanks Chrissy
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You'll have to have a system installation disk. If you will give me the specs on the machine (probably located in the battery compartment) I'll lead you to the correct system.
Was dit antwoord nuttig?
3 opmerkingen:
ok here it is and if you have a reputable place I can Buy a system instalation cd from would be appreciated.
G4 iBook 800MHZ 640 MB 40 gig HD combo
door
Your best OS install would be 10.4. I believe you might be able to use the restore discs for an iBook, which are located here.
door
Mayer- based on the posters three different questions, each stating a different story on how the iBook was acquired, I don't believe the poster is being entirely truthful. You may want to reference back to this.
door
Hi Josh,
Thank you for the quick response. I bought Panther to start, and then Ill get tiger after I install Panther. I found out it has 10.2 on it, so i have to go thru the motions and do Panther first.
Thank You again :)
Voeg je antwoord toe
chrissyo2361 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 614
