Inleiding
Removing the display requires cutting through the adhesive around the perimeter of the screen. After the adhesive is cut, it cannot be used to re-seal the display in place, so you'll need to apply a new set of adhesive strips.
Some images in this guide use a 2015 iMac, which has minor visual differences. These differences do not affect the repair procedure.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:iMac Intel 21.5" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge in the stand to stabilize the iMac.
Gereedschap gebruikt in deze stap:Tweezers$4.99
If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
Peel off the old strips of adhesive using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
After all the old adhesive is removed, carefully clean off the adhesive residue with high-concentration isopropyl alcohol (90% or greater) and a lint-free cloth. Wipe in one direction, not back and forth.
Lay out the adhesives strips beforehand so you won't accidentally install a strip in the wrong place:
Strip 01 on the top left
Strip 02 on the top right
Strip 03 on the right vertical
Strip 4R on the bottom right, dark side facing up
Strip 4L on the bottom left, dark side facing up
Strip 05 on the left vertical
Start with strip 03, which goes on the right vertical side of the rear enclosure.
Grasp the blue tab and peel the short piece of backing off the back of the strip to expose a section of adhesive to attach to the enclosure.
Insert the tip of a spudger into the hole at the end of the strip where you just removed one layer of backing. Insert the spudger from the side that still has a layer of white backing on it.
With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pulling up against the spudger to ensure the strip is taut, and stick it onto the frame.
Work your way counter-clockwise around the perimeter of the iMac, adding three more adhesive strips in the same manner:
Grasp the red pull tab on strip 4R and pull to separate about 2 inches (5 cm) of white backing from the strip.
Align the adhesive strip to the bottom edge by positioning the microphone notch over the microphone hole.
If your iMac does not have a microphone hole, align the right end of the strip such that the L-bend sits next to the right vertical adhesive. The L-bend should not overlap the right vertical adhesive.
Once you have aligned the strip, carefully set the left exposed edge onto the iMac to secure the alignment.
Gently set the display in place over the iMac and align it carefully.
Insert the display power cable into its socket on the logic board.
After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
Remove the film from the two bottom strips by reaching in from above with a pair of tweezers and pulling the blue tabs straight up from the bottom edge of the display.
Reconnect the display power and data cables for the final time.
Gereedschap gebruikt in deze stap:Microfiber Cleaning Cloths$3.99
Steady the display with one hand as you remove the protective film in the following steps, or rest it lightly against the iMac's enclosure.
17 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Thanks so much for this thorough guide. I had never dared do something like opening a computer and changing the hard drive. Not on an iMac, anyway. I was successful in changing my HDD with a SSD.
