Ga door naar hoofdinhoud
Sony Xperia Z3 Back Cover Replacement
Wat je nodig hebt
  1. Sony Xperia Z3 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 3 Sony Xperia Z3 Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 3 Sony Xperia Z3 Back Cover Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Heat the back cover of your Xperia Z3 to loosen the adhesive underneath.
    • If you use an iOpener, follow these instructions for use.
    • Lift up the back cover with a suction handle and put an opening pick in the gap.
    • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
    • Don't put the pick in too deep under the back cover to not damage any parts inside the phone.
  2. Sony Xperia Z3 Back Cover Replacement: stap 2, afbeelding 1 van 2 Sony Xperia Z3 Back Cover Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • There are two adhesive strips in the center of the phone connecting the rear case to the battery, you'll need to remove them to open the phone.
    • When the edges of the cover are free from adhesive, tilt it to allow access to the battery tabs.
    • Use tweezers to pull the two black adhesive strips out of the phone but don't pull just yet.
  3. Sony Xperia Z3 Back Cover Replacement: stap 3, afbeelding 1 van 2 Sony Xperia Z3 Back Cover Replacement: stap 3, afbeelding 2 van 2
    Plastic Cards
    $2.99
    Koop
    • Gently pull out both of the adhesive tabs out of the phone, parallel to the rear cover.
    • If the adhesive tabs break, try to use a thin flat plastic tool such as a plastic card to remove the last of the adhesive. If the adhesive is stubborn, heat it with an iOpener or hair dryer and pry again.
  4. Sony Xperia Z3 Back Cover Replacement: stap 4, afbeelding 1 van 2 Sony Xperia Z3 Back Cover Replacement: stap 4, afbeelding 2 van 2
    • After pulling out the adhesive tabs, you can lift the back cover and remove it.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
118.732 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.090 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 6,116
