Inleiding
Use this guide to replace a cracked or broken screen in your Samsung Galaxy A50.
Note: The function of the fingerprint sensor might be lost after this screen replacement. Security patches installed after September 2020 don’t support this repair.
This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
You’ll need replacement adhesive to reattach components when reassembling the device.
Wat je nodig hebt
Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Start by switching off your phone.
Heat an iOpener and apply it to the back cover to soften the adhesive.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
Use a spudger to disconnect the front camera by prying the connector straight up from its socket.
Use the flat end of a spudger to pry up and disconnect the interconnect and display flex cable from the daughterboard.
Carefully bend both cables out of the way.
Heat an iOpener and apply it on the display for at least two minutes to soften the adhesive underneath.
Place a suction handle close to the right edge of the display and pull with firm steady force for 30 seconds to loosen the adhesive.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Insert a plastic card into the loosened left edge of the phone.
Press the plastic card in and slide it back and forth until you cut through the entire adhesive.
Once you are sure you cut through the adhesive, remove the four opening picks from the corners.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
70 andere personen hebben deze handleiding voltooid.
24 opmerkingen
considering it is embedded within the display assembly, any chance that the fingerprint sensor is affected by replacing the screen?
Hi Steve, the fingerprint sensor is not embedded within the display as you can see here. The sensor is fixed under the frame and can be seen through the hole in the frame.
Hey, I followed this procedure to replace my screen and now, whenever I am charging my phone it keeps on rebooting itself every 3-5 seconds, or even when it’s not charging and is just idle. I tried to open it up and realign everything however it didn’t help and kept rebooting. So I am not quite sure what I did wrong and was wondering if you have ever experienced that, and what to do about it.
sounds like you may have damaged the battery in some way, try replacing the battery!
