Ga door naar hoofdinhoud
MacBook Air 11" Mid 2011 Solid-State Drive Replacement
Wat je nodig hebt
  1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Koop
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: stap 3, afbeelding 1 van 2 MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: stap 3, afbeelding 2 van 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Solid-State Drive: stap 4, afbeelding 1 van 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: stap 5, afbeelding 1 van 2 MacBook Air 11" Mid 2011 Solid-State Drive Replacement: stap 5, afbeelding 2 van 2
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Conclusie
112 andere personen hebben deze handleiding voltooid.
16 opmerkingen
Note: if you're installing a blank SSD, you'll want to format it with Disk Utilities) before the OS X installer will recognize it.
aaronmiller - Antwoord
Could not have been any easier, with this guide.
Thank you very much!
916sp - Antwoord
is it possible to replace an 128 GB Solid State Drive with an 240 GB? (MacBook Air, 11", Mid 2011)
zimmermatthias - Antwoord
Does anyone know if the Samsung 960 pro 512gb m.2 drive is compatible with this machine?
Mark - Antwoord
No, is not, I just bought a 1TB Samsung 960 EVO m.2 and had to return it, for not being compatible. (is smaller and the pin-out is not the same)
fjlbandeira -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 32
Afgelopen 7 dagen: 187
Afgelopen 30 dagen: 833
Altijd: 238,689
