Ga door naar hoofdinhoud
Logitech MX Master 3 for Business Mouse Feet Replacement
Wat je nodig hebt
  1. Logitech MX Master 3 for Business Mouse Feet Replacement, Soften the mouse feet adhesive: stap 1, afbeelding 1 van 3 Logitech MX Master 3 for Business Mouse Feet Replacement, Soften the mouse feet adhesive: stap 1, afbeelding 2 van 3 Logitech MX Master 3 for Business Mouse Feet Replacement, Soften the mouse feet adhesive: stap 1, afbeelding 3 van 3
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master 3 for Business Mouse Feet Replacement, Separate the mouse foot adhesive: stap 2, afbeelding 1 van 3 Logitech MX Master 3 for Business Mouse Feet Replacement, Separate the mouse foot adhesive: stap 2, afbeelding 2 van 3 Logitech MX Master 3 for Business Mouse Feet Replacement, Separate the mouse foot adhesive: stap 2, afbeelding 3 van 3
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. Logitech MX Master 3 for Business Mouse Feet Replacement, Remove the right and rear mouse feet: stap 3, afbeelding 1 van 2 Logitech MX Master 3 for Business Mouse Feet Replacement, Remove the right and rear mouse feet: stap 3, afbeelding 2 van 2
    • Repeat the previous two steps to remove the right and the rear mouse feet.
  4. Logitech MX Master 3 for Business Mouse Feet Replacement, Reassembly information: stap 4, afbeelding 1 van 3 Logitech MX Master 3 for Business Mouse Feet Replacement, Reassembly information: stap 4, afbeelding 2 van 3 Logitech MX Master 3 for Business Mouse Feet Replacement, Reassembly information: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  5. Logitech MX Master 3 for Business Mouse Feet Replacement, Remove the front mouse foot: stap 5, afbeelding 1 van 1
    • Remove the front mouse foot.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Clay Eickemeyer
68.062 Reputatie
453 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.525 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 353
