Ga door naar hoofdinhoud
Logitech MX Anywhere 2S Mouse Feet Replacement
Wat je nodig hebt
  1. Logitech MX Anywhere 2S Mouse Feet Replacement, Heat the mouse feet: stap 1, afbeelding 1 van 1
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the mouse feet for about two minutes.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
  2. Logitech MX Anywhere 2S Mouse Feet Replacement, Separate the mouse foot adhesive: stap 2, afbeelding 1 van 3 Logitech MX Anywhere 2S Mouse Feet Replacement, Separate the mouse foot adhesive: stap 2, afbeelding 2 van 3 Logitech MX Anywhere 2S Mouse Feet Replacement, Separate the mouse foot adhesive: stap 2, afbeelding 3 van 3
    • Insert an opening pick between a mouse foot and the lower case.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • If the pick feels stuck, apply more heat before continuing.
  3. Logitech MX Anywhere 2S Mouse Feet Replacement, Remove the mouse foot: stap 3, afbeelding 1 van 2 Logitech MX Anywhere 2S Mouse Feet Replacement, Remove the mouse foot: stap 3, afbeelding 2 van 2
    • Peel up and remove the mouse foot.
  4. Logitech MX Anywhere 2S Mouse Feet Replacement, Remove the remaining feet: stap 4, afbeelding 1 van 3 Logitech MX Anywhere 2S Mouse Feet Replacement, Remove the remaining feet: stap 4, afbeelding 2 van 3 Logitech MX Anywhere 2S Mouse Feet Replacement, Remove the remaining feet: stap 4, afbeelding 3 van 3
    • Repeat the previous two steps to remove the remaining mouse feet.
  5. Logitech MX Anywhere 2S Mouse Feet Replacement, Reassembly information: stap 5, afbeelding 1 van 3 Logitech MX Anywhere 2S Mouse Feet Replacement, Reassembly information: stap 5, afbeelding 2 van 3 Logitech MX Anywhere 2S Mouse Feet Replacement, Reassembly information: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Één andere persoon heeft deze handleiding voltooid.
Alex Diaz-Kokaisl
125.846 Reputatie
592 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.525 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 61
Altijd: 1,648
