Ga door naar hoofdinhoud
HTC One Speaker Replacement
Wat je nodig hebt
  1. HTC One Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 HTC One Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 HTC One Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. HTC One Speaker Replacement: stap 2, afbeelding 1 van 1
    • Pry the back loose and lift. The back panel will come off with time.
  3. HTC One Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. HTC One Speaker Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. HTC One Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. HTC One Speaker Replacement: stap 6, afbeelding 1 van 2 HTC One Speaker Replacement: stap 6, afbeelding 2 van 2
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. HTC One Speaker Replacement: stap 7, afbeelding 1 van 2 HTC One Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. HTC One Speaker Replacement: stap 8, afbeelding 1 van 3 HTC One Speaker Replacement: stap 8, afbeelding 2 van 3 HTC One Speaker Replacement: stap 8, afbeelding 3 van 3
    • Completely remove the motherboard.
  9. HTC One Speaker Replacement: stap 9, afbeelding 1 van 2 HTC One Speaker Replacement: stap 9, afbeelding 2 van 2
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
Conclusie
16 andere personen hebben deze handleiding voltooid.
Alex
664 Reputatie
1 Handleiding geschreven
USF Tampa, Team 12-1, Blackwell Fall 2014 Lid van USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 Leden
7 handleidingen geschreven
2 opmerkingen
Ok I will good
Raguraman - Antwoord
Where to buy speaker???
bharatdshmkh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 19,444
