Ga door naar hoofdinhoud
Apple Powerbook 5300 Trackpad Replacement
Wat je nodig hebt
  1. Apple Powerbook 5300 Trackpad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Trackpad Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Trackpad Replacement: stap 3, afbeelding 1 van 1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Trackpad Replacement, Trackpad: stap 4, afbeelding 1 van 2 Apple Powerbook 5300 Trackpad Replacement, Trackpad: stap 4, afbeelding 2 van 2
    • To begin the replacement process, refer to the prerequisite guides listed in the details portion of the guide.
    • To begin, carefully grip the bottom portion of the computer as pictured.
    • Next, lift up on the front portion of the laptop.
    • Watch out for the ribbon cable. Damage to this cable may result in harm of computer peformance.
    • Carefully disconnect it by grasping the cable, pulling straight up and out of its connector.
  5. Apple Powerbook 5300 Trackpad Replacement: stap 5, afbeelding 1 van 2 Apple Powerbook 5300 Trackpad Replacement: stap 5, afbeelding 2 van 2
    • While holding the mouse button in place, unscrew the two screws (Torx #8 ).
    • Then slide the button out, maintaining hold of the cable as pictured.
  6. Apple Powerbook 5300 Trackpad Replacement: stap 6, afbeelding 1 van 2 Apple Powerbook 5300 Trackpad Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the last torx #8 screw holding the trackpad assembly in place.
    • Now the entire trackpad will lift out of place.
    • Disconnect all ribbon cables from their connectors.
    • Note: refer to the first picture for a reference for reassembly.
Conclusie
Scott
155 Reputatie
5 handleidingen geschreven
Cal Poly, Team 25-30, Garner Spring 2011 Lid van Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 5,887
