AC Power Inlet
5 Antwoorden 2 Score |
Late 2006 iMac Blinking (white) power indicator, no boot |
3 Antwoorden 1 Score |
My iMac will not turn on? |
3 Antwoorden 0 Score |
Can I swap the logic board for a PC mother board in an old iMac? |
5 Antwoorden 4 Score |
Power light on but screen stays black |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
1.83 GHz (EMC 2104 iMac4,1), 1.83 GHz (EMC 2110 iMac4,2), 1.83 GHz (EMC 2124 iMac5,2), 2 GHz (EMC 2114 iMac5,1), 2.16 GHz (EMC 2114 iMac5,1)
Troubleshooting
There are no troubleshooting guides for the iMac Intel 17" at this time.
Upgrades
You can cost-effectively upgrade a number of components in the iMac Intel 17".
- Memory: If your iMac is still running with only the stock RAM, upgrading with 512 MB or 1 GB of RAM will provide a dramatic performance boost at minimal cost.
- Hard Drive: 80, 160, 250, or 500 GB hard drives came standard with the iMac Intel 17". You can upgrade the drive up to 2 TB.
Identification and Background
You can verify that you have a iMac Intel 17" by checking the processor information through "About This Mac" in the Apple menu.
Use the iMac identification system to help you identify your machine. iMacs tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
The iMac Intel 17" was the first desktop Mac based on an Intel processor.
