Ga door naar hoofdinhoud
iMac Intel 17" IR Board Replacement
Wat je nodig hebt
  1. iMac Intel 17" IR Board Replacement, Access Door: stap 1, afbeelding 1 van 2 iMac Intel 17" IR Board Replacement, Access Door: stap 1, afbeelding 2 van 2
    • Loosen the two captive Phillips screws securing the access door to the iMac.
    • Remove the access door from the iMac.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac Intel 17" IR Board Replacement, Front Bezel: stap 2, afbeelding 1 van 1
    • Remove the following four screws:
    • Three 6 mm T8 Torx.
    • One 8 mm T8 Torx.
  3. iMac Intel 17" IR Board Replacement: stap 3, afbeelding 1 van 2 iMac Intel 17" IR Board Replacement: stap 3, afbeelding 2 van 2
    • Flip your iMac over and lay it stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the Front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  4. iMac Intel 17" IR Board Replacement: stap 4, afbeelding 1 van 3 iMac Intel 17" IR Board Replacement: stap 4, afbeelding 2 van 3 iMac Intel 17" IR Board Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
  5. iMac Intel 17" IR Board Replacement: stap 5, afbeelding 1 van 1
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
  6. iMac Intel 17" IR Board Replacement: stap 6, afbeelding 1 van 1
    • If necessary, remove the piece of kapton tape(it is ok to toss this) wrapped around the microphone and camera cables.
  7. iMac Intel 17" IR Board Replacement: stap 7, afbeelding 1 van 2 iMac Intel 17" IR Board Replacement: stap 7, afbeelding 2 van 2
    • Disconnect both the camera and microphone cables.
  8. iMac Intel 17" IR Board Replacement, IR Board: stap 8, afbeelding 1 van 1
    • Remove the two T8 Torx screws securing the IR Board to the rear case.
    • The IR board should fall away from the logic board after removing these screws.
  9. iMac Intel 17" IR Board Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the IR Board cable from its socket on the IR Board.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 6,039
