AirPort Extreme Card
8 Antwoorden 1 Score |
Why do small plastic balls fall off the bottom of my laptop? |
14 Antwoorden 20 Score |
Completely reset from factory settings |
13 Antwoorden 2 Score |
will not start up from HD or CD |
Broken Power Socket on Logic Board |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Troubleshooting
Track down a number of hardware problems using the iBook G4 14" 1.42 GHz Troubleshooting Guide.
Upgrades
There are a number of components in the iBook G4 14" 1.42 GHz can be cost effectively upgraded.
- Memory: The iBook G4 14" 1.42 GHz has one RAM slot. You can add up to 1 GB of memory to your computer. Browse the RAM category, or check out our easy iBook G4 14" 1.42 GHz RAM installation instructions.
- Hard Drive: Browse our hard drives and upgrade today. Oh, and with our tools and instructions, you can even install it yourself!
- Optical Drive: The 8x SuperDrive allows you to read and write both CDs and DVDs. Browse our optical drive category for additional optical drives. Install your new optical drive yourself, the easy way.
Identification and Background
Use the laptop identification system to help you identify your machine. iBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
