AirPort Extreme Card
3 Antwoorden 1 Score |
Is the DC-In what I plug the power cord into? |
4 Antwoorden 0 Score |
Does anyone make a DDR RAM greater than 1GB? |
5 Antwoorden 5 Score |
iBook G4 powers on, but goes to blank blue screen after Apple icon |
2 Antwoorden 2 Score |
Where does small rectangular magnet with residue go? |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
1 GHz, 1.2 GHz, 800 MHz
Troubleshooting
Track down a number of hardware problems using the iBook G4 12" Troubleshooting Guide.
Upgrades
There are a number of components in the iBook G4 12" 800 MHz-1.2GHz can be cost effectively upgraded.
- Memory: The iBook G4 12" 800 MHz-1.2GHz has one RAM slot. You can add up to 1 GB of memory to your computer. Browse the RAM category, or check out our easy iBook RAM installation instructions.
- Hard Drive: Try a blazing-fast 7200 RPM drive. Browse our hard drives and upgrade today. With our tools and instructions, you can even install it yourself!
- Optical Drive: The 24x Combo Drive allows you to read both CDs and DVDs and write CDs. Browse our optical drive category for additional optical drives. Install your new optical drive yourself, the easy way.
Identification and Background
Use the laptop identification system to help you identify your machine. iBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
