HDD Removal
1 Antwoord 0 Score |
Laptop valt spontaan uit al bij het opstarten of na een paar minuten |
Geen opstart enkel 4 sec power led en dood |
Werkgeheugen hoe te vervangen |
16 Antwoorden 298 Score |
My Toshiba laptop powers up, but the screen is black. |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background
Toshiba was a multinational corporation credited with inventing flash memory and for being one of the biggest producers of consumer electronics in the world. However, due to a series of financial issues and scandals, the company declined and eventually sold 80.1% of their personal computer business to Sharp Corporation in June 2018. Sharp renamed the brand ‘Dynabook’, and purchased the remaining 19.9% of the business two years later on June 30th, 2020.
Toshiba laptops sometimes use modular design, which makes them more repairable. Modular design means that components of the computer are designed to be easily removed and upgraded, making features like the storage customizable for the user’s needs. This category contains repair guides and other helpful information for these Toshiba laptops:
- Toshiba Equium A210
- Toshiba Portégé
- Toshiba Satellite
- Satellite Pro L650
- Toshiba Dynabook AX 53D
- Toshiba Dynabook T552-58G
- Toshiba Mini NB505-N500BL
- Toshiba NB205 N330PK
- Toshiba NB255-N250
- Toshiba NB305
- Toshiba Portégé R700 14L
- Toshiba Portege R835-P56X
- Toshiba Portege Z835-P330
- Toshiba Qosmio X305-Q704
- Toshiba Qosmio X505-Q850
- Toshiba Qosmio X505-Q860
- Toshiba Qosmio X775-3DV80
- Toshiba Satellite C875-S7304
- Toshiba Satellite P105-S6024
- Toshiba Satellite P55W-C5200X
- Toshiba Satellite S55t-C5225
- Toshiba T2400CS
- Toshiba Tecra 530CDT
- Toshiba Tecra 8100
- Toshiba Tecra 8200
- Toshiba Tecra R940
- Toshiba Tecra M2
- Toshiba Tecra M3
- Toshiba Tecra M5
- Toshiba Tecra M11
There are also several Toshiba-brand Chromebooks. A Chromebook runs on the Chrome operating system (OS), developed by Google. If your Toshiba computer uses the Chrome OS, you may be able to find repair guides and support for it in the Toshiba Chromebook category.
Identification
These laptops will be labelled clearly with either Toshiba or Dynabook on the outside of the case, and below the display. Model names are located to the right of the trackpad, if at all.
A serial and model number are located on a sticker on the bottom of the device.
