Battery
1 Antwoord 0 Score |
Best OS to run on this netbook with 1gb of ram? |
1 Antwoord 1 Score |
Why can't my computer connect to the internet? |
Why my computer is running slow? |
Help! My computer will not turn on. |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background
The Toshiba NB305 has a 10.1 inch screen and a 1.66 GHz Intel Atom Processor. Its flash memory size is 250GB and its RAM is 1 GB DDR2-SDRAM. The power button is located in the center on the clutch, right above the keyboard. Toshiba NB305 doesn’t come along with a second number pad like its larger cousins because it is made to be easily portable. It has a front camera at the top of the screen and its battery lasts 11 hours. It uses Windows 7 starter and its hardware platform is PC.
Identification
It has a label that tells you the laptop model number in the bottom of the laptop so you can differentiate your laptop from other Toshiba models. The official name is Toshiba Mini NB305-N410WH. The outside case is frosted white in color with silver letters.
