Clutch Cover
4 Antwoorden 1 Score |
Booting SSD drive from WallStreet. |
2 Antwoorden 1 Score |
I have a power adapter. Do I need a Battery to use my mac? |
1 Antwoord 1 Score |
Where is the display inverter on the Wallstreet? |
6 Antwoorden 1 Score |
Why does this mac keep going to sleep? |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
233 MHz (0k L2 Cache), 233 MHz (512k L2 Cache), 250 MHz, 266 MHz, 292 MHz, 300 MHz
Troubleshooting
Track down a number of hardware problems using the PowerBook G3 Wallstreet troubleshooting guide.
Upgrades
There are a number of components in the PowerBook G3 Wallstreet that can be cost effectively upgraded.
- Memory: The Wallstreet has two RAM slots. You can place a 256 MB chip in each one for half gigabyte of memory. Browse our Wallstreet RAM selection for a chip that suits your need for speed. You must use a low profile chip in the lower slot, but the upper slot can be whatever you choose. Don't forget to install it using our free iFixit PowerBook G3 Wallstreet RAM installation instructions.
- Hard Drive: With our tools and instructions, you can install your new hard drive yourself!
- Optical Drive: Wallstreets are not inherently able to play DVDs. They require a special DVD decoder that fits into the PC card slot. Even if you have the decoder, you can only watch DVDs in OS 9. It will not work in OS X or classic because Apple never developed the hardware for it.
Identification and Background
The new PowerBooks came in three screen sizes; a 12", 13.3", and 14.1". It also came at three CPU speeds; 233MHz, 250MHz, and 292MHz.
Use the laptop identification system to help you identify your machine. PowerBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
