AirPort/Bluetooth Board
13 Antwoorden 7 Score |
MacBook not recognizing battery, not even in coconutbattery |
1 Antwoord 1 Score |
Can a MBP Mid 2012 support a 32GB DDR3 RAM? |
9 Antwoorden 23 Score |
MacBook Pro 2011 to 2012 logic board swap? |
4 Antwoorden 3 Score |
bad crayon/body odor smell coming from keyboard |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
A1286 (EMC 2556 MacBookPro9,1) 2.3 GHz, A1286 (EMC 2556 MacBookPro9,1) 2.6 GHz, A1286 (EMC 2556 MacBookPro9,1) 2.7 GHz
Identification and Background
The MacBook Pro 15" Mid 2012 Unibody was released in June of 2012.
The Mid 2012 model has the same model number, A1286, as the previous iterations. As with the models from in 2011, the MacBook Pro 15" Mid 2012 Unibody's case is composed of a single block of aluminum, following the same process of the MacBook Unibody and the MacBook Pro 17" Unibody.
Use the laptop identification system to help you identify your machine. MacBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
Technical Specs
Display:
- 15.4-inch (diagonal) LED-backlit glossy or optional antiglare widescreen display with support for millions of colors.
Storage:
- 500 GB or 750 GB 5400-rpm, hard drive
- Configureable to: 750GB 7200-rpm hard drive, 1TB 5400-rpm hard drive, 128GB solid-state drive, 256GB solid-state drive, or 512GB solid-state drive
Processor:
- 2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6 MB shared L3 cache.
Memory:
- Configureable to: 4 GB or 8 GB of 1600MHz DDR3L memory
Wireless Connectivity:
- 802.11n Wi-Fi wireless networking; IEEE 802.11a/b/g compatible
- Bluetooth 4.0 wireless technology
Graphics and Video:
- Intel HD Graphics 4000
- NVIDIA GeForce GT 650M with 1GB of GDDR5 memory and automatic graphics switching
- Thunderbolt digital video output
- 720p FaceTime HD camera
Battery:
- Built-in 77.5-watt-hour lithium-polymer battery
Ports:
- Two USB 3 ports
- Thunderbolt port
- MagSafe power port
- SD/SDXC card slot
- FireWire 800 port
- Audio line in
- Audio line out
- Kensington lock slot
Dimensions:
- Height: 0.95 inch (2.41 cm)
- Width: 14.35 inches (36.4 cm)
- Depth: 9.82 inches (24.9 cm)
- Weight: 5.6 pounds (2.56 kg)2
