AirPort Board
1 Antwoord 1 Score |
Waarom springt mijn accu percentage van ~50% naar 7% |
1 Antwoord 0 Score |
Ik wil in mijn Bios SMC maar er wordt om een wachtwoord gevraagd.HELP? |
Why do the adapter and magnet connection of my MacBook Pro overheat? |
Kan ik mijn logic board vervangen met de 'niet retina' versie? |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
A1398 (EMC 2673 MacBookPro10,1) 2.4 GHz, A1398 (EMC 2673 MacBookPro10,1) 2.7 GHz, A1398 (EMC 2673 MacBookPro10,1) 2.8 GHz
Background and Identification
The Retina MacBook Pro design was first introduced in 2012. A year later on February 13, 2013, Apple released the Early 2013 Retina MacBook Pro with an incremental update to the processors and an increase in the base memory configuration. This laptop can officially support macOS 10.15 Catalina, but not macOS 11.0 Big Sur.
To warrant its new “Retina“ branding, the Retina MacBook Pro 15” features a 2880x1800 display. This screen is driven by integrated Intel graphics and an Nvidia graphics chip. The computer switches between integrated and dedicated (Nvidia) graphics depending on the task at hand.
Each version of the laptop includes an Intel quad-core processor running at 2.4 GHz, 2.7 GHz, or 2.8 GHz. On purchase, the computer can be fitted with 8 GB or 16 GB of memory, but this choice cannot be upgraded later. The battery is also glued to the chassis, making it more difficult to replace than earlier iterations of the MacBook Pro.
To identify your MacBook Pro, look on the bottom of the laptop. The serial number will be written in small print, and you can use Apple’s serial number lookup to find your exact model. For more information about the exact hardware, click the Apple icon in the top left of the screen and select “About This Mac.“ This MacBook Pro is version 10,1 and model number A1425, but these numbers are shared with the 15” model from 2012.
Specifications
Display
- 2880x1800 pixels
- 220 ppi
- 16:10 aspect ratio
- Can support two external 2560x1600 displays from the Thunderbolt ports
Processor
- Intel Core i7
- 2.4 GHz quad-core (turbo to 3.4 GHz)
- 2.7 GHz quad-core (turbo to 3.7 GHz)
- 2.8 GHz quad-core (turbo to 3.8 GHz)
Graphics
- Intel HD 4000
- Nvidia GeForce GT 650M
Storage
- 256 GB, 512 GB, or 768 GB
- SATA III SSD
Ports
- Two USB 3.0 ports
- Two Thunderbolt ports
- HDMI port
- 3.5mm headphone jack
Wireless
- 802.11a/b/g/n Wi-Fi (2.4 GHz and 5 GHz)
- Bluetooth 4.0
Power
- 95 Wh battery
- Charging via MagSafe 2
Additional Information
Apple Support: MacBook Pro 15” Early 2013 specifications
