Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Vragen Bekijk alle
iPhone 4S No Backlight Issue
I have an old iPhone 4s that has no backlight, but if I hold it in light I can see the LCD working. I have tried restoring in iTunes and replacing the screen. There is gunk on the capacitors near the display cable so could that be it? If so, how can I remove it without knocking the components off the board? The previous owner had it sitting in a closet for years, so dust and gunk could have accumulated then.
EDIT: I don’t know what I did, but now the backlight turns on for a second showing the Apple logo, but then turns off again and won’t illuminate
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
could be a bad backlight filter
Update (04/20/24)
check that filter for continuity
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
How could I fix that?
door
@braydendcooper it requires microsoldering equipment its not an easy repair for just anyone. have you got a multimeter
door
Yes, I do have one
door
@tech_ni the filter has no continuity.
door
Voeg je antwoord toe
Brayden Cooper zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 86
