Ga door naar hoofdinhoud
Repair and disassembly information for the ROG Ally, a handheld gaming console made by ASUS. Released in 2023 and identified by model number RC71L.
24 Vragen Bekijk alle
left stick only moved up and down
my asus rog ally was working perfectly for a couple weeks. and then it started where the left stick only moved up and down. so I went into the bios and I saw the mouse cursor kept moving to the right. and this is because of the left stick! if I pushed on the left stick to the left, it would stop the mouse cursor but it couldn't move it back to the left. once the cursor gets to the right edge of the screen, it's stuck and you can only move up and down. if you switch to a different tab or page in the bios, you'll see the hand cursor keep moving to the right.
Is dit een goede vraag?
Score 3
1 Opmerking:
Opened up the ally joystick and noticed that the plastic piece that tranverses the left right sensor slide mechanism had broken off. I need to find a replacement joystick assembly. I saw a reddit post which indicated that the joysticks on the ally are identical to the win gpd 4. Anyone have a link to a replacement unit? https://www.reddit.com/r/ROGAlly/comment...
door
Voeg een opmerking toe
2 Antwoorden
I'm having the same issue. Happened out of nowhere. Was fine for a month and then turned it on today and it was like that. It's very weird cause it's not stick drift. It only drifts in bios. Actual menus and games it only moves up and down with no drift. Which tells me it's not the actual stick. It's software related.
Was dit antwoord nuttig?
Same here, I opened a brand new Ally rog and noticed this issue, so far don't know how to fix it.
Update:
I contacted ASUS service and was told it will take 1 or 2 months to get fixed due to no parts are available currently(in mainland China). I bought two ALPS RKJX21224001 stick controller and replaced both without broken the warranty seal. It's quite easy to open and replace the controller.
5 opmerkingen:
Dude my rog is doing this too
door
On the phone with asus support so will keep you updated !
door
I contacted ASUS service and was told it will take 1 or 2 months to get fixed due to no parts are available currently(in mainland China). I bought two ALPS RKJX21224001 stick controller and replaced both without broken the warranty seal. It's quite easy to open and replace controllers.
door
I keep trying to keep this thing. And everyday I'm disappointed and feeling cheated. At this point I want to smash it to dust. Because I'm not buying anything else for this POS.
door
I have the same issue with my ally, any one figured how to fix this
door
Voeg je antwoord toe
Patrick Nguyen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 65
Afgelopen 30 dagen: 321
Altijd: 5,796
