Ga door naar hoofdinhoud
Repair and troubleshooting information for the Kushlan 350DD, an electric wheelbarrow-style cement mixer.
1 Vragen Bekijk alle
Barrel not spinning or frozen.
After storing for a few months, I flip the switch, and it is making a humming noise. However, the barrel does not spin, I cannot spin it manually before I take it apart, I was wondering if anyone had experienced the barrel, frozen or not spinning. I did check in the breaker button is not tripped.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
There should be a large capacitor on the motor. That could of gone over time. Most mixers are ran on a worm drive gearbox so you can't rotate the drum by hand. Is there any way to safely rotate the drive mechanism? It could be jammed with sitting.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
After testing, it appears to be a dead capacitor. Thank You!
door
@Joseph Galaska No problem, hope you get it working.
door
Voeg je antwoord toe
Joseph Galaska zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 68
Altijd: 450
