Ga door naar hoofdinhoud
Guides and repair information for external storage devices made by Synology.
10 Vragen Bekijk alle
Need component detail and circuit diagram for missing reset button
As per image - in a previous heavy handed RESET with an overlong paperclip, i have managed to break the reset switch from the motherboard.
I need some details of a suitable component and then the wiring / orientation for the four pins that will need soldering.
Alternatively, if someone knows how to temporarily short these four pins out then that would also be helpful, eg clockwise from top left 1 - 4, do I need to be jumping 1 to 3 or 3 to 4 or whatever.
Thanks,
Michael
Is dit een goede vraag?
1 Opmerking
That did the trick; many thanks :)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @michaelfoggin ,
The yellow pins seem to be on the same Ground plane so I would try to short yellow with the pink circle, as per below.
What device is it? Do you have the model number?
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hi,
it's a DS1817+
Thanks for speedy reply :)
door
Voeg je antwoord toe
Michael Foggin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 398
