Ga door naar hoofdinhoud
Repair and information guide for the Frigidaire FFU2067FW, an upright freezer introduced in 2007 that offers 20.2 cubic feet of freezer volume and features an automatic defrost system. This page covers information for model numbers matching the pattern FFU2067FW*.
1 Vragen Bekijk alle
Frostless Upright Freezer Has Ice Inside At Bottom
We have a Frigidaire model LFFHZ067DW2 that is not working as the red light in the front toe space is on and water frozen on the inside floor. Looks like there is solid ice at the inside back at the bottom. Unplugged the unit, opened the door and let it thaw all night. Water dripped out of the edge of the door which we left open and underneath where the condensate line exits from the back right corner as seen from the back. Took off the drain hose and found some water and a little trash like wet dust balls. Mopped up about half a gallon of water this morning wiped out and plugged in. It is now cooling and red light is off. Does this represent a defrost timer that needs to be replaced or is this the kind of maintenance that do periodically? What is the normal temp for this unit? Thanks in advance for any assistance.
Is dit een goede vraag?
Score 1
8 opmerkingen
I have had a similar problem. Although a different freezer, it worked again after having it defrosted, we ended up getting a technician coming out for a dishwasher, actually, but he checked out the freezer too, and said it was just a periodic maintenance you should do every 6 months or so.
door
Thanks Esa but I don't think a frostfree unit requires this type of maintenance. At least it is not stated as such in our manual or troubleshooting suggestions. I think that jayeff's response that followed nailed it with his diagnosis.
door
Mine does the same
Frigidaire commercial upright
Had it on max and it was getting to -10ish and when it self defrosts I think the drain is freezer instead of drawing and the bottom freezes over I see a little puddle of water
I broke up the ice and used hot water to clear the drain but kept occurring every 2-3 months
So I took the thermostat from the highway where it was like -10 to 6-7 and it’s about 10 now and hopefully that works
Just not sure if I should put it to where it gets 0 Fahrenheit if 10 is to warm for a deep freeze
door
@Benjamin Wood
What is the model number of the freezer?
door
Have an upright Frigidaire model # LFFHU1765DW15. Discovered a sheet of ice in the bottom of the freezer. Melted that w/a hair dryer but there is still a lot of ice behind the back panel. Where is it supposed to drain? Need to see if the drain hose is clogged?
door
3 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Did you mean a LFFH2067DW2?
If so it has an automatic defrost system.
The automatic defrost cycle is controlled by the defrost timer. The defrost cycle occurs once every 8-11 hours (depends on the manufacturer. I don’t know how exactly how often for your model but it should be within this time frame). The auto defrost cycle takes about 20-25 minutes to complete.
During the auto defrost cycle the compressor and the evaporator fan are both turned off and the temperature is allowed to rise to >32 deg. F to melt the ice formed on the evaporator unit at the back inside the compartment at the bottom behind a panel and to drain away to the evaporator pan under the freezer. The melting process is sped up by turning on a defrost heater which is under the evaporator unit. When the temp reaches 32+ F the defrost thermostat operates and the heater is turned off and the compressor and evaporator fan are turned on again to drive the temp back down to the set temperature . The defrost timer is also reset so that the cycle will occur again sometime between 8-11 hours later.
The normal set operating temperature is approx. 0 deg.F
Water/ice problems in a refrigerator or freezer are usually because of a problem with the auto defrost cycle. Due either to a blocked drain tube, a faulty defrost heater or a faulty defrost timer (or control board if the unit has one instead)
If the drain tube is blocked then the ice melt water can not run away and will overflow the bottom of the freezer and also will build up as more ice when the freezer temperature drops again after the defrost cycle has finished.
If the heater is faulty then the ice will continue to build up as enough ice i.e. all the ice has not melted during the defrost cycle.
If the defrost timer is faulty then the auto defrost cycle will most probably never happen so the ice just keeps on building up. Usually there is no water overflow as the temp has never been allowed to rise that far to melt any ice or the heater turned on, but it may be an intermittent problem etc so it could happen
The ice will just continue to build until eventually it ices over the evaporator fan and it will stop running and the freezer temperature will rise due to no cold air being blown throughout to keep it at the correct temp. So the complaint will be freezer too warm ;-)
If everything was working as it should there wouldn’t be that much ice build up in 8-11 hours anyway so not much ice has to melt and drain and then evaporate under the freezer but if there is a problem it may take a few days or more before it becomes evident
Apologies for the long answer but thought that if you understand the process it is easier to know what might be wrong when problems occur.
Here’s a link showing all the parts for your freezer and their location which may help in the future.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Thanks for the detailed response and parts list link. Most helpful! We had the defrost timer replaced 3 years ago and that fixed it then. It may have gone bad again and that doesn't say much for the replacement part quality. I guess maybe the heater or the board this time? Going to give it a shot. Thanks again!!
door
@jcouchjr52
Disconnect the power from the fridge and then disconnect the heater element and use an Ohmmeter to measure the element's resistance.
I'm not sure what it is but usually they're between 25-50 Ohms. If it is open circuit it is faulty
If the element tests OK you may want to check the power to the element.
IMPORTANT Be safety aware the element operates at mains voltage i.e. 120VAC Unfortunately I don't know how to force a defrost cycle for your model so that you can easily check for the voltage.
Also hope I didn't mislead you when you say that you're going to check the "board". If you mean "control board" your model doesn't have one. I meant that some refrigerators and freezers have a control board instead of a defrost timer not as well as.
In your model everything is controlled by the defrost timer, the temp thermostat and the defrost thermostat.
Freezer compressor and evap fan run until the temp thermostat signals set temp is reached, this stops both. When temp rises a few degrees they're started again to drive temp back down so as to maintain temp close to set temp. This action continues until the defrost timer starts auto defrost cycle. The defrost thermostat ends auto defrost cycle when temp reaches 32F and compressor and evap fan are started again and the temp thermostat controls operation until next defrost cycle.
door
Based off their comment of 'wet dust balls' it honestly sounds like their evap coil may be dirty and need cleaned. A dirty evap coil is pretty much a guaranteed way to freeze an evap far past what a defrost cycle can handle. Just an FYI for anyone who may not know.
door
Same problem, ice sheet forms at the bottom every 6 months after shutting the freezer down and letting the ice thaw at the bottom vent and drain. After 3 years of this bs, I decided enough was enough and decided to change the U curve in the drain tube and add a deli tray with a side hole for the end of the tube to provide drainage by gravity flow. It worked!
2 opmerkingen:
After 3 months still no ice build up in bottom of freezer. Apparently the U curve was too much to allow drainage. Try and straighten enough to allow for gravity flow.
door
We did this pan thing too. Still getting an ice plug,right at the hole in bottom of freezer within 12 hours. We have had frosted contents. There is space all all around for air flow. This is a Frigidaire model FFFH17F2QWA. As near as we can tell from diagram there is no adjustment for defrost cycle timing.
door
Voeg je antwoord toe
jcouchjr52 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 95
Afgelopen 30 dagen: 419
Altijd: 18,672
