Problem With Wii? Can Any body Help?
My Wii Turn Off After I Play The Game For 15 - 30 Minutes And when I switch it on again and play the Game Again It Wont Start And Turn Off Again.Then After 30 minutes it work again.
Is dit een goede vraag?
i would say you need to turn it on and look in the back. i would bet your fan is not working. its a easy fix to do your self i have repaired lots with this issue . you may be able to stick a toothpick in there and bump the fan to get it working again. but i would replace it as it is going bad ;)
Was dit antwoord nuttig?
Sounds like overheating, but when game does not work in like 30 minutes, it may be two things.
1) Game disk if you play games what you get from game stores OR Flash memory if you play downloaded virtual console/wiiware games.[
2) Do you have problems with other games? If not, it can be the optical drive.
If you have warranty left, take it to nintendo to be repaired.
If you don't have warranty, here is a link to an new wii dvd drive:
See if anything is blocking the fans movement. It could be your system overheating. If so, this must be addressed as this is a fire hazard
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 19
Altijd: 2,813
