Ga door naar hoofdinhoud
2018 refresh of the Apple Mac mini. Processor options include 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5, and 3.2GHz 6-core Intel Core i7 processors.
86 Vragen Bekijk alle
What PSU connector is used?
Planning a battery powered MAC Mini 2018. It seems to have an additional row of pins compared to the previous 85w 2014 model. Does anyone know the pin out of this, and also if apple’s using a custom connector or if it’s a standard one I could find and crimp? Thanks!:)
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
Here’s a picture of the power supply:
The logic board header is a standard 20 pin.
Its not a simple replacement! As there are multiple voltages coming from the power supply.
Its just smarter just getting a DC to AC converter to run on a car or boat battery.
Many of todays trailers & cabin cruisers offer AC outlets which are directly wired to the motor or generator.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Thanks Dan - upvoted! I noticed the header looked “keyed” in the highres picture in the teardown, but might’ve just been my imagination. Considered using an inverter but trying to avoid the wasted energy in the conversion process. Keyed connector aside, Do you know if the pins are “paired” - the connectors under the soldermask seem to be linked vertically? Otherwise no worries happy to stick a multimeter probe in the outputs ;)
door
You really can't do want you want as there are multiple voltages.
Just like a PC you'll have multiple 12 volt circuits besides multiple wires servicing the same circuit and you still have a switch line and SMC sensor line mixed in here as well.
So as much as you want to by pass the power supply it's just not possible at this location!
Your only hope is to get a spare so you can take it apart. so you can redesign the unit.
Here you would strip away the AC part of the circuit and insert a DC version. So you end up with a DC to DC power supply.
And, yes the connector is keyed
door
nice information. thank you so much
door
Het nuttigste antwoord
Daniel,
I just opened up my 2018 Mini and measured the voltage (not plural) coming from the power supply connector as well as a continuity measurement of the logic board connector.MacMini2018_DC_Connector.pdf
As with the 2012 & 2014 models, the logic board needs ~12VDC. That’s it. The people claiming the 2018 power supply is outputting multiple voltages have clearly never opened one up and measured it. There is no basis to support this information as I have just confirmed for myself. As for the claims that these machines run on a “strict voltage tolerance”, I’m not buying that either. I ran my last Mini (i5 2014) on 13.6VDC because the point was to power it with a LiFEPO4 backup battery.
However (as noted in the drawing) the logic board connector shorts the pin marked with an asterisk (*) to 0V or GND. This is a little suspicious considering this connection is not made on the 20pin cable that connects the PSU to it. All other connections are mirrored. This could be Apple’s way of trying to foul up the not-so-savvy DIY enthusiast trying to convert his/her 2018 Mini to run on straight DC power. Meaning… it could be designed to where the power supply has to see that connection or else it’ll shut the computer down. Doubtful since I was able to measure voltage potential with the 20pin cable not connected. Probably more like ground loop prevention in some other part of the machine.
As for why they chose to use a 20pin connector to carry a single voltage… in a word - amperage. The previous models had a 85W PSU. 85W / 12V = 7A This one is 150W. So, 150W / 12V = 12.5A. They chose to use multiple runs of thinner wire instead of two big fat wires which is perfectly acceptable. Also because if one of the smaller wires break, it will probably still work. If too many break, it will have issues starting up. The only reason it needs such a big supply is for when it is starting up. It has large voltage spikes during that process. I measured them as high as 11A. It seems to idle around 2A. Any decent size Lead Acid or Lithium battery you use will simply laugh at that.
Keep in mind while looking at the diagram that it is drawn from the POV of looking at the CONNECTION SIDE of both the male and female counterparts. In other words, they are a mirror image of one another. I made sure to include the key on the end of the connector for reference. Hopefully this all makes sense.
Be sure to let me know how it goes if you are still planning on carrying out your initial plan. These machines are still pretty new and I imagine there are plenty of people like myself who are hesitant to start hacking up their machines which are probably still under warranty.
-Aaron
Update (11/24/2019)
Just thought I’d post this update. I did a dry run to confirm that the Mac Mini 2018 CAN be ‘simply’ modified to run on a straight DC supply. By following my pinout diagram posted earlier, I was able to temporarily affix some jumpers to the appropriate header pins and clip lead those to the terminals of a SLA battery and the computer started up fine. No weird, multiple voltages required.
Incidentally… I also tried a power supply I have laying around which is 100W @ 12VDC. As anticipated, the machine would not start from this supply as it is only capable off supplying ~8.3A. I imagine the battery is capable of 20A or more so it was the obvious choice for testing.
I will be carrying out the full mod in the coming days/weeks and will post again after completion.
Update (11/24/2019)
Just an update. I found that when bypassing the stock PSU on the MacMini 2018, it is possible to incur noise issues if you are using your system for audio applications as I am. Nothing incurable. Because I’m running a few other things off of the same battery/power supply unit, I found certain connections will have clocking noise injected into audio signals. Even with a proper star grounded audio hookup scheme. The reason this doesn’t happen with the internal switching unit is probably due to Apple’s robust power supply filtering. The cure for this is a 1:1 ISO Line Transformer. I bought a couple cheap Rapco units to cure any offending outputs. They work perfectly and my audio is dead quiet. No biggie but quite a few people seem to be viewing this page so I thought I would mention it for the audio folks.
Score 10
14 opmerkingen:
Aaron - You have a few errors in your drawing!
As to multiple voltages there are multiple 12volt services running in parallel gaging them together is not what you want here.
door
I’m not sure I understand your reply but… If you run a continuity test on both the logic board and power supply output (not while powered, of course) you will find that my drawing is indeed correct. As stated in my post, there are multiple conductors carrying 12V. There are also multiple conductors carrying 0V. Your reply would lead me to believe that you are under the impression they are coming from separate regulators but this is not the case. Spreading the voltage out over 7 conductors is just a way of supplying enough current to the logic board safely.
Have you opened up your machine and performed these test? If you are comfortable with it, I strongly urge you to do so and you will see for yourself.
door
@Aaron Thompson - Apple is doing both! Take a look at the power supply and you'll see there is two independent circuits.
door
Do you think a unit like this one could work:
http://www.mini-box.com/picoPSU-160-XT
perhaps with an adapter like they mention here: https://www.computerhope.com/issues/ch00...
door
Hi Aaron
Is there a power on signal, comparable to an ATX power supply (pin 14 green)?
I want to build my Mac Mini 2018 in a normal ATX case. For this I want to build an adapter between ATX power supply and Mac Mini.
According to the standard, the ATX power supply has three + 12VDC and one -12VDC connections.
Unfortunately I have not yet found a replacement cable for the Apple power adapter to use it for testing.
Dennis
door
9 commentaren meer tonen
As mentioned in my comment yesterday, the connector housing and the sockets can be ordered from Digikey. http://www.digikey.com/short/zqq9pf
Here is my progress so far on the mod using the pinout described by Aaron Thompson. I designed and 3D printed a little bracket that holds the Anderson connector in place. I was originally going to JB weld this in place, but I plan on redesigning the bracket so that it screws into the same holes that the original PSU was attached to on the frame. Or not. I don’t know. :-P
Score 3
5 opmerkingen:
Looks great. I like the Power Pole connectors.
door
I did the wiring exactly to the diagram. I get fan spin and a boot screen but then just after the apple logo pops up the machine turns off. I got it to the login screen once but then powered off.
door
What type of power supply are you using? Did you keep in mind the peak power draw during the boot up phase?
door
@curta I just re-read your previous comment and realized that you’re using the same power supply as Aaron. If his is working and yours isn’t, I would suggest double checking your connections. Also make sure you didn’t insert the pins into the housing mirrored. That could be bad.
door
I had to use the first two (8A) taps on the PSC in parallel. Sorry I didn’t mention that earlier.
door
Hi guys,
I'm about to embark on this endeavour with an M1 Mac Mini. Seems it uses far less power to boot and idle So i can get away with a mere 60W PS. Although Ideally I'd like to run it directly from a Lithium Ion battery, which when fully charged is 16.8V and when dead 11.8ishV.
I'm wondering if anyone here has had long term success in running their Mac Mini direct from a L-ion 14.4V nominal battery?
It's concerning to know the over voltage may simply blow up my Mac Mini if I take the risk to try it myself.
Cheers
Score 3
5 opmerkingen:
Have you tested this? It is my understanding that intel mini’s have DC-DC on board and it would make sense for M1 board to have the same.
door
To answer my own question, my M1 Mac Mini runs on 10.8-16.2V unregulated. At 10.8v it entered a low power mode. With a controlled load (OBS streaming) a normal load is 4.5% but when voltage drops below 11.4V the cpu usage goes to 7.5% and at 10.8V the M1 Mac Mini feels sluggish. It still works and operates. I’ve yet to test it at 16.8v (v-mount battery charging voltage).
door
@siritwitch Did you try it with charging voltage?
door
@sergeisilnov Yes, my M1 mini runs directly on the battery with no voltage regulation. Means while charging it sees up o 16.8V and works down to 10.8V when the battery cuts off.
door
@siritwitch Great, thank you
I'm working on a tablet with macOS and use macmini m1 mainboard for it
Removing dc-dc module should help to simplify it.
door
I had a 12V 10A power supply but that’s not enough to get past boot. I had a battery and it supported boot. Got it working and seems to function as normal while on battery. I tried it with a cigarette lighter socket in a car and it didn’t get past boot, not sure why. I used a high amperage locking barrel connector from switchcraft that fits in the chassis without having to modify it.
Score 1
2 opmerkingen:
Curtis,
Once again I apologize for not responding sooner. I don’t get over here much. You’ve obviously figured out by now that you need a PS capable of enough current draw to get over that initial hump at startup. The stock PS is 150W. 150W / 12V = 12.5A. The cigarette lighter in your car probably is current limited so you don’t damage your battery and need a jump start every morning, It possible that car batteries aren’t capable of firing like a lithium. Lithiums have that discharge curve that looks like a hockey stick. They work for what seems like ever and then all of a sudden, they’re just dead.
door
Hi, do you try to power on macmini by 13.6 LifePO4 batterry?
door
I’ve done this dc 12v out wires. I’ve kept the ac power so I solder bridged the exposed wires in my Mac mini (just 4+,1nc, 4- groupings not 20 wires). I drilled two holes in the front near the ir and power led for the two wires to come out. The power ac unit plug become loose so I had to wrap cello tape around the plug to stop it dropping loose.
this is eight years old Mac, but my last hold on to this operating system I spent several years coding on. Macs too expensive and I’m going focusing on software available on Pc , unity, fusion360 etc.
1 Opmerking:
I’m keen on getting a 12v battery for this. Got an expensive battery backed touch screen to make this thing portable. Such a cool concept to run a Mac mini as a portable. But dang all shops are closed for a month in the nz nation wide covid19 lockdown.
door
Voeg je antwoord toe
Daniel Lee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 87
Altijd: 6,173
