Ga door naar hoofdinhoud
Repair guides for the Shure SM58-LC Dynamic Cardioid Vocal Microphone.
9 Vragen Bekijk alle
On/off Switch Loose on Mic
Hi, the on/off switch on my new Shure SM58S is quite loose. When I turn the mic on, the switch slides to the off position VERY easily. Is there a way to tighten it - or should I return it and hope the next mic is better? Thank you for any help!
Is dit een goede vraag?
2 opmerkingen
This video is the WRONG answer. The question involved an SM-58S wired mic. Not the wireless unit shown here!
door
I am dealing with the exact same issue. Just called Shure to find out about a replacement switch but have not heard back yet. Any luck?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @jamie70lynn ,
If it is still within the manufacturer’s warranty period, I suggest that you return it for a replacement.
If it is no longer in warranty, here’s a link to a video that shows how to replace the switch.
I cannot find a replacement switch online, you may have better luck.
You could always try contacting Shure and ask if the switch is even available as a spare part.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jamie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 41
Altijd: 1,927
