Ga door naar hoofdinhoud
The Cadillac DeVille was originally a trim level and later a separate model produced by Cadillac. The first car to bear the name was the 1949 Coupe de Ville, a prestige trim level of the Series 62 luxury coupe.
30 Vragen Bekijk alle
2000-2005 CadillacDeville cigarette lighters not working
I replaced all 3 power window motors and regulators except drivers window and now I can't get any of the cigarette lighters to work. Sometimes the cigarette lighter light comes on and sometimes it don't, light on or off, lighter does not work, fuses are good under back seat ?
Is dit een goede vraag?
Score 2
4 opmerkingen
Where is the cigarette lighter
door
In the front under the dashboard.
door
El motor de mi Cadillac DeVille tiene un cascabeleo que podrá ser les agradezco su respuesta
door
@armando61730 Please start a new question; yours is not related to the current issue being discussed and is not relevant to that discussion.
Por favor comience una nueva pregunta; el suyo no está relacionado con el tema actual que se está discutiendo y no es relevante para esa discusión.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi @lejk2 ,
Besides fuse #65 in the fuse box under the rear seat did you also check fuses #22 & # 23 in the engine compartment fuse block?
This is for a 2002 Cadillac de Ville so hopefully it is the same for your year model.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Thanks very much ! It all started from using a phone charger that came apart and shorted out the cigarette lighter unit. 1st checked the fuses under the back seat witch was ok then replaced the whole front cigarette lighter and light unit , the light would work, cigarette lighter just wouldn't work until you said to check fuses #22 and #23 under hood, top of engine , check and found both 20A fuses to be blowned, I replaced both fuses and now the cigarette lighter works. Awesome and thanks ever so much again.
door
u were right it was 23 thank u good looking
door
From autogenius.info, on a 2003 Deville:
Underhood Fuse Block
The underhood fuse block is located in the front of the engine compartment between the windshield washer fluid reservoir and the power steering fluid reservoir on the passenger’s side of the vehicle
Minifuses
Fuse Usage
23 Cigar Lighter
Rear Underseat Fuse Block
To access the fuses, push in the two tabs located at each end of the fuse block cover.
Mini Relays
Relay Usage
58 Cigarette Lighter
MaxiFuses
Fuse Usage
65 Cigar Lighter
So there are two fuses and a mini relay that control power to the cigarette lighters and you'll need to check them all.
Score 1
The fuse is in under the hood where you might expect the battery. It’s up in the top right hand area, 20 amp fuse. Albeit, I don’t think that it is the fuse. If it was the fuse it would not work at all. but check the fuse first,
Voeg je antwoord toe
Leroy J Knight Jr zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 90
Altijd: 6,478
