Ga door naar hoofdinhoud
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
269 Vragen Bekijk alle
Will the JDS-040 fit on my ps4 controller when mine has JDS-050?
My Controller model is CUH-ZCT2U and the model of the port is JDS-050 so i wanted to make sure before i bought anything that might not fit, and if i do need JDS-050, where could i find one ive looked everywhere but i cant find it.
JDS-050:
JDS-040:
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I am in the same boat, need a jds-050 usb board and all I can find is the jds-040 board.. I'm gonna just order that one, the pin connectors are the same and had seen a wire diagram where they match the same, I am thinking the jds-050 was either an upgraded board or maybe a differnt manufacturer.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Same problem. Already tried a jds-040 board. It is not compatible.
door
so either buy a new controller or wait till they release the jds-050 to consumers
door
I have a CUH-ZCT2U (5th gen) and my controller has a JDS-055 board. My controller works when connected to USB but will not charge. I bought a JDS-040 board by mistake. The JDS-040 can be installed in the controller but the ribbon connector is on the other side and requires the ribbon cable be twisted to make it work. The JDS-040 does allow the controller to work over USB and the lights work but still not charging.
door
Kindly check Alibaba. They have tons of replacement parts for JDS-050 and all other port versions.
Voeg je antwoord toe
BurnedSpaghetti zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 71
Altijd: 6,372
