Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Vragen Bekijk alle
Unlock disabled iPhone 4s
I have used all the steps required to unlock and restore my iphone4s and during the process a message comes up on my laptop stating there's not enough space for it to carry on ?? Please help how or what do I do next
Is dit een goede vraag?
Score 24
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
1) if the phone is still fully operational, connect the iPhone to iTunes
2) connect the iPhone to a computer use iTunes to do a full backup -- If it asks if you want to transfer apps, say "no".
3) put the iPhone into DFU mode (should be a black screen, not a connect to iTunes symbol if done correctly), and allow iTunes to restore the iOS
4) Once it finishes restoring the iOS, iTunes will ask if you want to restore from the backup you just made. Simply agree to that, and you should be good to go.
Was dit antwoord nuttig?
Score 3
It sounds as tho you may have to hard restore that device thru itunes before you can get into it at all now
Score 2
This article will show you steps and tips on how to fix and solve the problem without iTunes.
Disabled iPhone: How To Fix Without iTunes
Score 2
There are several ways to unlock disabled iPhone 4s according to Appleā€™s official method. These include: Erase iPhone via iCloud if Find My iPhone is enable. Restore iPhone via iTunes if you have synced with iTunes. Sometimes, these 2 method may not be available for you if you have not synced your iPhone.
If so, FoneGeek iPhone Passcode Unlocker will be available since this tool can remove screen lock when you forgot the passcode.
Voeg je antwoord toe
Lindsay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 72
Altijd: 10,908
