Ga door naar hoofdinhoud
A baby monitor made by Infant Optics, Inc. The DXR-8 features a 3.5" screen , temperature sensor, night vision, and an interchangeable lens system.
33 Vragen Bekijk alle
Can you recalibrate the thermometer?
The thermometer/temp reader used to be very accurate, but now seems to be showing a high temperature compared to what the actual room temperature is. Is there a way to re-set it or recalibrate the thermometer?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@camillelynn I read through the manual. There is no reset option or reset button.
What I can suggest is completely disconnecting the battery and wait a few minutes and reconnect the battery. Maybe whatever miscalibration will reset in this manner.
They have a dedicated help line at info@infantoptics.com which may be able to let you know if this is a hard ware defect or simply a reset fix.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thank you for your thoughts! I'll give that a try.
door
Did this work? It doesn't work for me, and the temp has never been right. I just now figure that it's always a few degrees cooler than what it actually says. But that's frustrating.
door
I have a different issue.the temperature moves up and down from the top to rhe botton.After that, stops and shows a doble H H and the celsius or farenheit symbol . Any suggestion? Thanks
Voeg je antwoord toe
Camille zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 218
Altijd: 20,481
