Ga door naar hoofdinhoud
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1193 Vragen Bekijk alle
MacBook Pro suddenly dead and does not turn on
Hello,
My Macbook Pro suddenly shut down and is not turning on, no chime, no Apple logo. There was no exposure to water. (However, I had kept a steaming bowl of hot water right next to the laptop.But this was in an open kitchen)
The Pro had less than 10% charge when it suddenly shut down. I charged it for another 10 minutes and tried to switch on, but no luck. I charged it completely till the magsafe indicator turned green, still does not turn on. So assumed that the battery is charging fine. I opened the mac and saw no visible corrosion or moisture(two tiny dots below the battery case are white and haven't turned red)
I have tried the following already.
1. SMC reset - With the magsafe adapter connected, when I do the reset the charge indicator turns green from orange.
2. Disconnected and reconnected the battery connector - still no life.
Its been only a year and three months I bought this in India. Could the logic board die out so soon? How to pinpoint if it is indeed the logic board?
Thanks a lot!
Update (01/23/2017)
I am currently based in a small town in Germany with no apple genius store around. I will be visiting the store in February. Meanwhile any help would be appreciated.
Thanks!!
Is dit een goede vraag?
Score 29
35 opmerkingen
Disconnect the battery, then the keyboard, then plug in the charger and see what happens.
door
@madhu15 as Rany said, but reconnect the battery after disconnecting the keyboard. The 2015 13" will only boot when the charger is connected if the battery is plugged in too :)
If this doesn't work, remove the logic board and check the bottom for liquid damage.
door
Thanks for the prompt reply @reecee and @rany! I did the following in sequence
Disconnected battery --> pulled out keyboard cable --> reconnected the battery --> connected the charged.
Alas, nothing happened :(
door
@reecee I didn't know that. I thought it would start with charger alone. Point taken...
door
Try the same with trackpad disconnected...?
door
30 commentaren meer tonen
Voeg een opmerking toe
22 Antwoorden
Gekozen oplossing
When trying to attempt to boot it, press the trackpad. If it clicks, the MacBook is coming on (but is not displaying picture, chiming or another issue), if not, the MacBook is completely dead, which will be an issue with the logic board. The force touch trackpads will only click when the MacBook is on, so this is a good indicator when diagnosing these.
Remove the logic board and check it for any liquid damage. Remove the tape at the top of the board (this covers components, sometimes liquid is underneath this.
Clean any liquid with 95%+ isopropyl, but before cleaning, take a picture for reference, so we know what area was affected by the liquid (if the clean doesn't resolve the issues.
The MacBook should boot when the battery is reconnected and the charger plugged in, so there is clearly an issue with the logic board.
Was dit antwoord nuttig?
Score 19
29 opmerkingen:
Trackpad gives no click after reconnecting the battery and charger. So, as you said it is a logic board issue.
I'll try removing the board and see if there has been any accidental liquid spill without my knowledge.
Thanks
door
I have the same issue except my trackpad does click. But my screen is still black and heard no chime and my battery is fully charged
door
I had a similar issue, My Macbook Pro couldn’t switch on for over two weeks.
Finally I managed to resolve the problem and now it’s back and performing even better.
Follow this guide here: http://bit.ly/2qCKG0q
Hope this helps.
door
My macbook pro suddenly doesn't want to switch on nor charge. What should I do
door
Francis, I'm having the same issue and I wanted to check your link but it's broken. I hope you can see this message and send us an updated link. Thanks
door
24 commentaren meer tonen
Het nuttigste antwoord
Reset the SMC on Mac notebook computers
First, determine whether the battery is removable. Mac notebook computers that have a nonremovable battery include MacBook Pro (Early 2009) and later, all models of MacBook Air, MacBook (Late 2009), and MacBook (Retina, 12-inch, Early 2015) and later. Learn more about Mac notebook batteries.
If the battery is nonremovable:
Shut down your Mac.
Unplug the MagSafe or USB-C power adapter from your computer.
Using the built-in keyboard, press Shift-Control-Option on the left side of the keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds.
Release all keys.
Reconnect the power adapter.
Press the power button again to turn on your Mac.
If the battery is removable:
Shut down your Mac.
Disconnect the MagSafe power adapter from your computer.
Remove the battery. (Learn about removing the battery in MacBook and MacBook Pro computers.)
Press and hold the power button for 5 seconds.
Reconnect the battery and MagSafe power adapter.
Press the power button to turn on your Mac.
The LED on MagSafe power adapters might change colors or temporarily turn off when you reset the SMC.
Reset the SMC on Mac desktop computers
Follow these steps for iMac, Mac mini, Mac Pro, and Xserve.
Shut down your Mac.
Unplug the power cord.
Wait 15 seconds.
Plug the power cord back in.
Wait five seconds, then press the power button to turn on your Mac.
Thanks
Varun
Score 50
64 opmerkingen:
Hi Varun,
As mentioned above, mine is an early 2015 retina Pro and hence battery is not removable. Already tried the SMC reset. No signs of life.
Thanks
door
Try With Reinserting The Battery Connector
Thanks
Varun
door
What is the battery connector? The battery is not removable.
door
Thanks it worked.
door
@Madhu: Does your Macbook work again? I have a similar issue. Apple says that I am out of warranty and the German shop notebooksbilliger.de don't feel the need to repair my MBP (finally I consulted a lawyer).
door
59 commentaren meer tonen
I have the same problems TODAY. No response from Mac Pro 13 “ Retina Early 2015 after holding down the power button. I try the SMC reset . Plug out the AC power. HOLD THE KEYS: SHIIFT, CONTROL, OPTION, AND POWER SIMULTANEOUSLY FOR 10 SECS. THEN Release. Hold down Power button for 15secs. It power up again. IT works !
Score 6
6 opmerkingen:
I tried that several times it didn’t work, I had to open Mac up and disconnect the battery plug
I then plugged in AC power it worked!
I then shut Mac down re inserted battery plug thinking the battery was the fault but it all works as normal!
door
I’ve gone through same process and it ain’t working , I use a MacBook pro 2017
door
Thanks a ton. it works for me
door
Hi, I have the exact problem you do. My MB Air will startup normally if I leave the internal battery connection unplugged and just use the charging cord with the amber light on. The Air will start normally even if I shut it down (sleep as well) and plug the charger cord in and push the power on button.
If I plug the internal battery into the logic board the Air will not start from the battery or the charging cord.
I don't know if a new battery will solve this issue. Have you solved the problem?
door
It is not working for me too on Macbook pro 15 inch 2011.
The CPU fan runs, I checke the Ram, the Harddrive in the other Laptops. Everythings semms to be fine. The Capslock light is also not turning on.
Can anybody Help please...
door
1 commentaar meer tonen
Had a similar issue on my 13” Macbook Pro (late 2013). The battery died while the laptop was left running and it wasn't powering bank on. None of the reset key combinations suggested would power it on.
An authorized service center diagnosed the issue (charged me about $30) and told me I had to replace the topcase (cost: $500+) - since there was a problem with the power button.
  • Upon opening up the laptop myself (since it was a 5 year old laptop at the time and warranty had already expired) using iFixit’s Pro Tech Toolkit (costs about $70) and disconnecting the battery and then plugging in the magsafe connector, it powered back on. I then put it back to sleep by closing the lid and connecting the battery back in.
I indeed seem have an issue with the power button but as long as I maintain charge in the battery I don't have to use the power button, I can just easily continue to put it to sleep and waking it back up using just the lid. Oh and I can also restart without any problems. It's only when I let battery die, or shutdown, that I have to open laptop, disconnect the battery, and repeat the process.
Pro Tech Toolkit Afbeelding
Product
Pro Tech Toolkit
$74.95
Score 2
2 opmerkingen:
This worked perfectly for me. After trying all of those resets, the SMC and P+R key reset, I wasn’t expecting unplugging the battery to do the trick. But it powered right up after I reconnected the magsafe charger.
Anyone who’s having issues with their a1502 MBP not turning on, but green light on the magsafe should try this fix. I guess my issue is only if I let the computer run out of battery entirely. Then I have to disconnect the battery, plug in charger and then hit the power button and it comes to life-like the above post, I can close the lid and plug the battery back in right after, and everything is good.
But, If I had just tried this earlier, it would have saved me a lot of stress. Thanks Siddharth!
door
This worked for me too!! I thought I was hooped. Got the A1502 model in late 2015 and was able to resurrect it with this! Disconnected the battery inside, plugged it in, reconnected the battery and bam! Start-up music :)
door
I have tried all the above mentioned Methods.
The CPU fan runs, I checked the Ram, the Harddrive in the other Laptops.
The battery indicator also showing all the lightning as I have left 1hour for charging. Everythings seems to be fine. The Capslock light is also not turning on.
The back logo is also not turning on.
Score 2
2 opmerkingen:
had this problem and I did a SMC reset from the left side of Keyboard and after a year of trying to come up with a solution it now works \
door
Same problem with my MacBook Pro 2015. I tried to reset PRAM and this resolve my problem. After that i hear chime and logo appears.
door
For someone who doesnt work with all those method my macbook pro got green light on mag safe charger but always show up with red charger icon , try quickly move a bit of the charger then turn on suddenly ! I know its weird but its work for me
Score 1
2 opmerkingen:
Omg it worked
door
Wow, how you discovered this thing! It worked flawlessly!
I tried all tricks mentioned here: 1) SMC Reset, 2) Power+Trackpad, 3) FN+Control+Command+Power, all without any avails, still, no chimes or power on, and the Magsafe charge indicator kept off like no electricity.
Then I tried your trick. Voila, it was ON!
Thank you for your discovery-of-the-century!
door
Im having to do the same process of taking the back off and disconnect the battery and plugging into a wall outlet its really annoying but it does work,in this state my macbook is probably worth less then $100. Wondering what to do from here ? Buy new battery?
Update (05/13/2020)
You have to unplug the battery and plug it back in it will automatically start up don't let it shut off keep it charged keep it going cuz if it turns off going to have to unplug the battery and do all that again and that's a ##&&% taking that back off at everything so leave the motherfuker charging and you'll be good to go
Score 1
2 opmerkingen:
door
Actually, as long as it does not switch off and the battery does not go flat, it is fine ... so I can never let any of those situations happen!
Mine is a MacBook Pro from 2015, 15"
door
My macbook is not turning on. Not charging or not showing the battery level. When i plug the charger it has a dim green light.
Score 1
2 opmerkingen:
O nly dimlight is you , you lil dimwit sissy
door
Same as mine did you get any help on that...
door
Unfortunately I had the same issue. while working on my Mac air 13 , the battery died and after I had charged 100%, it still did not turned up. I tried all the options, however nothing worked. Ultimately, had to change the motherboard which was “costly”. I was told by apple care that there was a liquid found in the motherboard and hence it happened. It still does not seems to be a convincing reply to me. Seems to me it could be the moisture formed on some part in motherboard which could have caused it
Hello , have replaced my keyboard recently on MacBook pro retina 2015 15inch.. since when power on, I always hear chime but it doesn’t turn on. have tried all option described without success. noticed that fans blows slowly, and the heat pipe on logic board get very hot.
I took my computer to Lapin store and they shipped it to Apple, got a new logic board as this failed and was the main issue to this problem, cost $700. Computer is running great now.
Replace the battery. .
Remove the battery and connect the power cable directly. Wait for 5 blinks on the led, and in 10 seconds the laptop will boot. It's definitely the faulty battery… don't ignore service battery. The faulty battery manifests in ways unimaginable and unbelievable..
Hi,
Interesting reading, thanks for the input.
I've got a A1990 (2019 MBP) that doesn't power up, Tried everything possible (without opening the case), nothing works. It's on Apple care, but i am stuck on a little island, not even mail in repair possible from here. Even without the virus the next possible service center is far far away.
What else could i try without voiding the warranty?
We're living on a boat, it hasn't been very humid here though. But still, maybe the humidity sensor kicked in?
Also it caused some troubles over the last few months, the keyboard / touchpad was not detected after sleeping and it turned off a few times at around 30-50% charge. Maybe that indicates something else like the battery?
Thanks so much for helping!!
F
4 opmerkingen:
I kept reading into humidity issues ... living on a boat and having a Mac seems to be not the best combination ;)
door
Hi I could solve the Problem.
I clean all the logic board the alcohol or you can also do it with nailpolish remover but becareful not too much just a little bit of it.
Then I left the logic board disconnected overnight.
And next morning I tried with shift+fn+conttrol+option+command+power button at the same time and holding it down for at least 10 second and then wait for 5 more second then turn it on.
May be this could help.
door
@bim0321 Thanks, but that will certainly void my AppleCare ;)
door
My case is solved. Finally got back to civilization and got it fixed. Apple replaced the Logic board, the thunderbolt boards and the SSD. It's working again.
door
I'm having this problem too and I have tried everything and it still doesn't work. I have only had this MBP 2019 for less than a month
2 opmerkingen:
Read my recent comment may be it could help...
door
@tmg1706 did you come up with a fix? I am having the same issue with my mbp 2019
door
I am also facing the same problem. My macbook pro is just 3 months old and it is just dead. No response, nothing seem to work. Everything seems to be dead. No response coming from charger connection, cpu fans, any of the port's.etc.
Tried all key combination and nothing seems to wake this machine up.
Also, there is no apple care center in my city. Because of lockdown, can't go outside my city very easily.
Please suggest any other solution for this without voiding my warranty.
3 opmerkingen:
I am facing the same problem. I have tried all remedies suggested in the manual and kindly suggested by well–meaning friends here. Using the various keys on the left and right side of the keyboard with the power on–off key etc. Nothing worked. Due to lockdown in our city I can't even visit an Apple store.
door
Hi Jitesh, I am facing same issue. Did you get any fix for that till now?
door
Hi everyone, this just happened with 3 of my Macbooks in the last 4 months. Did anyone of you manage to get it fixed?
door
Same problem here. I placed my MB inside a casing a week ago so that it will not be accumulating dust. Last night when I turned on, it won’t. I tried every fix that would be possible including opening its back to remove battery, SSD card, and display, I tried also the CTRL+OPTION+SHIFT+POWERON.
Still it did not work. It does not turn on the fan nor attempt to turn on the fan but when I connect a phone charger, and press the power button, it quickly charges but suddenly stops charging. However when the Macbook's power adapter is connected, it charges the phone charger and continues charging. I also did resetting the NVRAM which is OPTIONS+COMMAND+P+R but still would not work.
Any help is highly appreciated.
Open up. Ease the battery connector off with your finger/Nail…don't use a screwdriver!
Plug in mains and see if it boots up… if it does leave on for a minute to recover machine…then turn off and remove mains…insert battery connector….if your machine is a fixed battery and connector then it must need an Ap Technician.
i dont know if this will help i had the same issue and nothing seemed to work all day i read loads of documents but still no joy with any of hte methods however the bit htat stuck in my mind for my 2016 mbp was htat the track pad was clicking for about 2 secods and then just tuen off. so i turned on the devise and just kept tapping on the track pad non stop till it booted . alsas it came on and im currently trying to reinstall a. new version of mojave
hope this helps
1 Opmerking:
unfortunately it switched back off
im plannig on opening it up tomorrow
door
Yes, it works!!! Thank you so much for this advice.
Sometimes my Macbook pro forcefully auto shut down and did not power on.
Above no method works for me.
Finally worked it some other method.
  • Close your display and plugin for 7/8 hours.
  • Open display, my MacBook automatically powered on.
My MBP 2016 Touch bar does not power up. I have tried all the solutions in this page, still no success. When I press the power button, the Trackpad works, also external CD drive or USB sticks are light up and working, but nothing else. Strangely when I disconnect the battery from the logic board, both fans start working. stuck with this machine.
My MBP 13 Retina Early 2015 won’t give any sign of life either. No chime, no spinning fan, nothing on the screen.
It was working fine untill one day when I was browsing on the internet. I went to the kitchen to get a drink, and when I came back the MBP was suddenly turned off. At first I thought that maybe the battery was completely empty but it wasn’t, I remembered I had a good 50% left.
Since that day, the MBP had never turned on again or given any sign of life. I tried all solutions I could find, SMC/PRAM reset, battery disconnect, tried another battery/magsafe. I even opened up the case multiple times to see if I could find anything strange, but havent found anything yet. No liquid damage, no loose or broken connectors, nothing.
The battery is able to charge from amber to green so the magsafe and battery seems to be working.
The SMC reset showed a good response with the magsafe LED, meaning the keyboard works and so does the power button. Yet no fan spinnging or any other signs of life.
Any other ideas?
If the logic board is dead, I will sell it for parts, the Retina screen is brand new (replaced a year ago) and the body is in perfect condition.
2 opmerkingen:
It is probably the logic board. But you can also disconnect all the connectors and see if it starts. Open the case and disconnect everything to the logic board, especially the left I/O card, then try a few times to start it and see if it comes on. Then reconnect each connector and see which one causes it to shut off again. That would indicate where the problem is.
How to remove all connectors:
https://m.youtube.com/watch?v=oE9_5b5Yzi...
door
Thanks Adam. Late response from me but unfortunately this didn’t help.
I’m now selling the mbp for parts, considering it is probably the logic board causing the problem.
Thanks again for your help.
door
Voeg je antwoord toe
Madhu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 51
Afgelopen 7 dagen: 295
Afgelopen 30 dagen: 1,557
Altijd: 1,289,955
