Ga door naar hoofdinhoud
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Vragen Bekijk alle
What is the voltage from the charger suppose to be?
I have a Macbook air 1466 with liquid damage. The macbook still works but has some malfunctions which I'm trying to fix. I have the schematics for this model and this says that the voltage from the adapter should be 18,5 volts on PP18V5_DCIN_CONN. I have 16,6 volts here and I cannot find a short.
I'm in doubt that the schematic is the final version and want to know for sure that the power rail is really suppose to be 18,5v before I set 18,5v from my power supply on the rail to find the short.
Can somebody confirm that this macbook uses 18,5v and not 16,6v?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
All Macbooks (save the new Retina Macbook which uses a USB-C charging port) use nominally 20V power supplies (the magsafe chargers, 20V will be marked on the bottom of them). In actuality the peak output voltage is under 19V (18.5V as you mentioned is normal), the same as almost all other laptops. However, note that this is peak. The actual supply voltage depends on the draw required (which depends on charge state of battery and workload) and will be either approximately 14.5V, 16.5V or 18.5V. So 16.6V is normal.
Hope that helps!
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Thank you that is helpful. I checked my own retina and that was using 20v like you said, that was somewhat confusing for me.
So bottom line, the board should be able to handle 18,5v, right?
door
See the pin out on the Mag-Safe adapter on the right side of this page, sounds like this is not your issue: https://en.wikipedia.org/wiki/MagSafe
Score 3
Voeg je antwoord toe
Joe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 204
Altijd: 21,997
