Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2203 Vragen Bekijk alle
iPhone 4s is stuck @ Recovery Mode, cant start iPhone
Hello,
I got an iPhone, that wont start up and stucked in Recovery Mode since I was trying to restore it, because I had some problems with the software.
iPhone was working without any problems, before restoring.
What I already tried?
-changed PC
-changed iTunes version
-restore while in DFU mode
-change battery (according to some sources, it was the problem, didnt help in my case)
-configured hosts file
-tried different usb port
-tried different usb cable
As you can see, I tried many things, to solve this problem, but I still get every time at about 70% of restoring progress the error 29.
I just dont know, what I can do.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Hi,
I believe that the error 29 comes down to a damaged or non-functioning power/charging circuit.
On the iPhone 4S, there are a total of 6 small passives (resistors and capacitors) to the right of the battery connector. These are typically damaged as the battery is removed, or because the flathead screwdriver slips and knocks one off. These components are shown on the following picture (Yellow circle):
Please make sure that none of these components are damaged, i.e. blown or missing.
There is a video showing a possible fix here: https://www.youtube.com/watch?v=wOXmrFnD...
Was dit antwoord nuttig?
2 opmerkingen:
Hey,
thanks for your answer.
I think you´re right, because I changed battery several times, and this might damage some components.
Can you explain what hes doing in the video?
I just see him touch the components with a screwdriver.
Best Regards.
door
Hey, please help me, I really dont understand what the guy in the video was doing.
Thanks
door
You can check and find the solutions and methods at here too: How to fix and solve Error 29 code problem
In iPhone 4s mobile is gone recovery mode and showing black screen
Voeg je antwoord toe
iphone4s zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 379
