Ga door naar hoofdinhoud
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Vragen Bekijk alle
How do I get the cameras to work again?
I have had this phone for 2 months and both cameras stopped working. I try opening the app and it instantly dies and goes back to the home screen. Also on snapchat the screen shows up black and will not show anything that the lens would be showing.
Is dit een goede vraag?
Score 117
50 opmerkingen
If there's someone who can help me, my HTC can not take pictures.
door
I have exactly the same problem on my camera and other apps such as instagram,snapchat,whatsapp every app that uses the camera does not let me take a picture, Someone please help it's stressing me out now I've had this problem for almost a month
door
I have a solution that worked for me! Go into Settings - Power - Scroll down to the bottom and uncheck Fast boot - Restart Phone.
door
My sefile is not run. And than dou effect is not work. Now i cant
door
unchecking fast boot worked for me! yay thanks!
door
45 commentaren meer tonen
Voeg een opmerking toe
20 Antwoorden
Gekozen oplossing
Hi Buddy
My HTC Camera is not working at all, when i tried to open the camera it open and it shows black screen and then after sometime it comes to home scree.
Can you tell me how to rectify this issue.
Rgds
Sameer
Was dit antwoord nuttig?
Score 58
27 opmerkingen:
Privacy guard... Yeah.. Problem fixed. Thanks :)
door
I didn't find Privacy guard. Where did you find it? The main camera is not working.
door
Its worked!! Thank guys.
door
Bro, I had also this problem. Now it solved
http://www.gogorapid.com/fix-samsung-gal...
door
22 commentaren meer tonen
try doing a hard restart . please update the phone software ,
please close all other background app and rsetart the system .
for more follow Guide - steps fix to Phone Camera in phone and try to see if this helps to fix the camera
Score 12
1 Opmerking:
My duo camera stopped working but front camera is still working well please help me .
door
Hey Jacob, here are some things things that I recommend you try:
-Try to 'clear data' under 'camera' in app manager.
-If you're using Lastpass try and do a factory rest.
- If you are using the Lastpass option "Enable fill into apps" and turn it on in accessibility settings then the camera issue might be there. Maybe if you turn it off camera works fine.
-Let me know what happens.
-Hope this helped
Score 6
1 Opmerking:
Please I need help my HTC m8 windows can't open camera
door
SUCCESS!!! first of all thank you for all the suggested solutions. What worked for me? Someone suggested that we should find the apps that use the camera and disable them and VIOLA!!!! that worked for me.
go to settings
then apps
click on each app and scroll to the bottom of each app (each one has to be done individually)
under permissions if the camera is listed you scroll back up and disable the app.
i did not disable messenger though
I VE GOT MY CAMERA BACK!
THANK AGAIN!!!!! HOORAY!
Score 4
Guys, this is the solution. It worked in my phone.
go to settings then to applications. See which application is using the camera then force stop or disable it. For my case, I forced stop the application called privacy guard and my camera worked perfectly henceforth.
Score 3
2 opmerkingen:
how do you determine with app is running your camera
door
door
I turned off phone took battery out blew off any dust put battery back and cover it started to work again
Score 3
3 opmerkingen:
you can't take the back off a htc m8 because you have to take the screen out to get to the back of them
door
Not true mine slips off the back it's a bit hard but does open
door
Not sure about m8 my phone is about 3 years old
door
Score 3
2 opmerkingen:
no this does not work. stop making false solutions
door
This did work for others, that was rude. Not everyones issue has the same cause.
door
When faced with this problem,
1. Review the last apps you downloaded (Settings>Apps>new downloads)
2. Review to see if it uses the camera for any reason
3. If yes, press the Force stop Bottom
4. If 3 above didn't work, you will have to uninstall the app (s)
I did the above and it turned out an app (Swifty) which I recently downloaded, was the cause of the problem.
Score 3
2 opmerkingen:
My HTC M8 is brand new from box but camera not working. I have tried to follow all the instructions here but to no avail. What should I do to this brand new hone?
Phillip
door
If u installed Security 360 just remove this app and restart your mobile phone.
door
Score 3
I found an answer but I can't explain it just yet. I have a program that allows my home screen to rotate. Whenever I enable that program the camera does not work in portrait mode. Just get a black screen. However the camera does work in landscape mode. If I disable that rotate program the camera works in both portrait and landscape mode. Not sure what caused this to happen just yet. I thought I remember it working just fine at first. My guess is something got borked and it will take some cache clearing or something to resolve fully. As for now my work around is just to disable the screen rotation when I want to use the camera.
Score 3
What i did is i just stopped the camera ihad!!and i don't know if this is a option for you-but i just downloaded another camera and it's working nicely! Hopefully so can you!!!!----sue
Score 3
1 Opmerking:
I downloaded a new camera but its
still not working
door
I just opened the back on my phone and fiddled and cleaned it a bit where the connection is, when I rebooted it worked again...
Score 3
I had the same issue even after factory reset. Then I upgraded my software to marshmallow....
The camera is now properly working
Score 3
UPDATE I got my camera back for a while, it broke again. I'm tired of trying to fix this. I have had no camera for a while now
Score 2
I don't have no front camera every time I go to the camera and pick the little square box I don't see the selfie sign.
1 Opmerking:
Same issue. Can anyone assist please?
door
My camera won't work the message" camera has unexpectedly stopped " shows up did all the above and a factory reset and still doesn't work
1 Opmerking:
I suffering from same issue, if you have any solution please share
door
I had a lot of problems with my htc...
I'm disappointed....
And also my camera doesn't work
2 opmerkingen:
My HTC Desire 530 front facing camera has also stopped working...did all the above...no help...very frustrating ..can someone please help all of us ? HTC peeps?
door
سلام مهسا ، مشکلت رو تو تلگرام بگو راهنماییت کنم
@HaCKeR071
door
Hi
Duo camera is blocked problem after replace camera , plz help me ,
1 Opmerking:
HTC makes great phones with too many issues which gives customers tons of migraine. In the long run it's not worth buying.
door
Has anyone contacted HTC and has their phone fixed? I've had my HTC One M9 for 3 days and this has just happened to me.
My camera it's not working
2 opmerkingen:
My HTC One M8 main camera has stopped working after change of the accumulator battery. Just a black screen. I will try two solutions provided here - turning off "Autorotate" and switching off all the apps that use camera. Will tell you the result soon...
door
My HTC One m8 selfie camera is not working camera app quits to menu when I go to selfie mode and on other apps like snapchat selfie can shows black image
door
Voeg je antwoord toe
Jacob FUEHRER zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 38
Altijd: 188,753
