Ga door naar hoofdinhoud
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
42 Vragen Bekijk alle
My HTC One X screen has just gone blank...
My HTC One X was working perfectly fine but then suddenly the screen went black. I tried connecting it to the charger but the red charging light wouldn't come on. I also tried ringing the phone but nothing happened. I tried holding the power button for about 15 seconds, still no response. The final thing I tried was to connect it to the computer to see if the computer would detect the device however the computer didn't. I don't know what else to do, HELP?!?
Is dit een goede vraag?
Score 13
8 opmerkingen
keep holding the power button and the volume up it worked for me
door
Thank you , Yasa. A great fix. Did the trick !
door
@Yara Mansour I love you rn I you are my life tbh
door
This totally saved me! Thanks!
door
hey guys it worked forme too. since yest night ithad this issue suddenly turned blank. when called said switchoff. but could get whatsapp call, but could not attend. alarm was ringing but could not slide to off. but this trick worked thks very much
door
3 commentaren meer tonen
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
Mine blanked too! This twist thing (below) actually worked:
http://www.htconeforum.com/forum/htc-one...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Great!! Twisting got my black screen problem solved! Thank you for sharing :)
door
i have the same problem , Adinda Adinda how solved black screen problem
door
It seems your phone died for broken motherboard or battery, you need to send for professional check.
1 Opmerking:
Are the local phone repair shops fine? And do you know how much they will charge to repair it.
door
You have what's know as the black screen problem, ( I have too) there is a fix but it involves taking the phone apart and putting a bit of paper between a ribbon cable bend. I'm looking for the fix again myself. In the meantime I bought a new phone LG G2, (good phone recommended) I'll post back here once I find the fix, but it's not for noobs.
Found it: http://www.htconeforum.com/forum/htc-one...
hameed_kakar2003@yahoo.com
mine was taken back to china.apparently not even flashing wold help and no one knew wat the !&&* was going on.am still waiting for my phone
How to fix htc one x overheating? Touchscreen sutting down automaticly
Voeg je antwoord toe
Haroon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 42,537
