Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Vragen Bekijk alle
trying to restore but itunes says enter passcode
Hi, my iPhone was disabled from too many password attempts, now as I try to restore it, iTunes says I need to enter a passcode, but on my phone, it will only go to the emergency call screen and won't allow me to enter my passcode. I'm not sure how to get this to work.
Is dit een goede vraag?
Score 120
27 opmerkingen
Did you ever get a fix to the problem with recovery telling you that a password was needed?
door
This happened to me with an iPhone 6 iOS 8.1
I have no idea what to do. I'm pretty sure I have tried everything also I have only had the phone a little over a week :(
door
um we need help not uh i have it i dont know what to do im stupid if your going to help help but if your not then shutup
door
HI it should work , press hold the home button and power button same time when it shows connect to ITUNES then connect restore to your backup(if you have backup) mean while you authorize the phone when it is restoring then it will go to your restore point. if you do not have restore go to factory settings. Try and update recently I have done successfully
door
i need my iphone 4s on lockrightnow
door
22 commentaren meer tonen
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
I was having this same problem listen to these instructions step by step.
Have your phone plugged in with iTunes.
Turn your phone off.
When it is off, hold the lockscreen, while holding that wait til the logo shows up, then continue holding that and hold the home button. When the apple logo dissapears, let go of the lock screen, and wait 10 seconds while still holding the home screen, then follow the prompt on iTunes. And boom, factory settings. Took me a while to figure out, I had to pull some old knowledge about jailbreaking to figure it out. Don't worry it is completely safe, I was having the same problems as you guys. This will work :)
Was dit antwoord nuttig?
Score 50
47 opmerkingen:
That actually worked!
door
But my lock button doesn't work
door
Hey ugh this happens after doing what you said any pointers?
door
It worked you're awesome
door
42 commentaren meer tonen
To avoid the passcode lock, you must hard reset your iPhone by holding down the lock button and the home button down simultaneously until the iPhone turns off.
Press and hold the home button while the iPhone is off and plug it into your Mac while still holding the home button down. The iPhone will turn on by itself when it is plugged it, but because you are holding the home button down, it will boot up in Recovery Mode.
iTunes will say "iTunes has detected an iPhone in Recovery Mode. You must restore it." It is now okay to release the home button.
Procede to restore your iPhone to factory settings, and then you may select a backup to restore it to after it has been erased.
Hope this helps! It's been a while since I've done it. Let me know if you need clarification on the steps. :)
Score 8
14 opmerkingen:
it didnt help it just said iphone is disabled connect to itunes but when i try it does it every time
door
Doesn't work when iPhone is disabled and says connect to iTunes
door
What do I do it's not working my parents will kill me if they found out
door
it at first now my phone won't shut totally off or on it has iTunes and cord emblems
door
My lock button doesn't work please help?!
door
9 commentaren meer tonen
If it is not the lock code, maybe it is the iPhone backup password. Have you set such an encryption on your backup while you sync your iPhone to iTunes? If so, try the backup password.
However, if it won't let you enter passcode, you can use a toll called Tenorshare ReiBootto put your iPhone into then out of recovery mode. This may fix the stuck screen.
Note: Don't hard reset your iPhone because it will erase all iPhone data and settings.
Score 3
2 opmerkingen:
The "Hard Reset" on the iPhone will not erase anything. I have done it many times. Please view this page about restarting your iPhone.
door
But I think it's screen passcode when iTunes ask you to enter one passcode, because when we forgot iPhone passcode, firstly we want restore from iTunes, but even if synced your iPhone to iTunes, when we use iTunes to restore iPhone, we may be asked to enter passcode, in this case, you can turn to Eelphone iPhone Unlock to unlock iPhone without passcode, with the detailed guide, we can unlock iPhone without password in several steps, and what we should do is clicking.
door
When on recovery mode already connected to iTunes, if it turns on and says need passcode but your iPhone is disable, try home button hold down connect to one computer with iTunes open already, once on recovery mode, disconnect and connect to another computer with iTunes open already, usually works the first time, but keep switching until it goes thru the whole restore process.
Score 3
1 Opmerking:
My phone is 6splus and i did follow the steps at least 5 times as mentioned you. but it doesnt work and still showing ur itune is not successfully restored because ur iphone is locked with passcode. Please help me!!
door
If you happened to lose the data on your iPhone due to wrong deletion, jailbreak, factory settings restore, software update and so on, you may need to restore iPhone to find the lost files back. With one recovery software, you can easily restore iPhone without iTunes
Score 1
Try this step...
1. Turn off your iphone.
2. Then put it in the ref not in the freezer for about 5 minutes to make it cool a little bit.
3. After 5 minutes get your phone and, stand with you one foot while holding your iphone.
4. Then put you iphone on the floor and smash it with a hammer.. then go out and buy a new one!
Score 1
3 opmerkingen:
why when trying to restore iphone 4s it keeps asking for password if i knew that iwouldnt be on here is there a real solution to this or o i chuck the iphone away and never buy anything apple again
door
apple must of losts millions with the iphone because of the stupid apple id and passwords is there a genuine way to get back into the iphone
door
Lol love it.
door
Voeg je antwoord toe
Kristie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 60
Altijd: 223,747
