Ga door naar hoofdinhoud
install OS X 10.5 from a bootable USB HDD?
Okay, so in a couple of weeks my iBook g4 12" is going to arrive, it has a 30gb hard drive and 256mb of RAM.
I have copied the .DMG file of the Mac OS X 10.5 install disk to my external USB hard drive and made sure its a bootable drive, so my question is.... If i hold down Option (alt) key and select the drive, will it install OS X as ive planned?
if it helps any, the iBook's hard drive has been wiped and there is NO operating system installed at the moment.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
PowerPC Macs can only be booted from the internal drive or from a Firewire drive. (sorry!)
The newer Intel Macs can be booted from USB if certain conditions are met, but not your iBook G4. See https://discussions.apple.com/thread/177... for more info.
I just went through this same issue myself, so I feel your pain.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Should i just burn the file to a dvd and do it that way instead?
door
You might burn a DVD and try that -- especially if you have access to a PowerPC Mac to make the install disk with.
You may also find something useful here: https://discussions.apple.com/thread/120... -- this page is about going from PowerPC to Intel, but some of the info may still be of interest to you.
Also please see http://support.apple.com/kb/HT1544?viewl... for basic facts about installing OS X 10.5 Leopard
door
As Steve stated you can't install via an external USB optical drive. Your iBook should have an internal drive which may work if you set up the disk correctly and use the correct media.
You may want to give Apple support a call and see if you can still buy the required recovery disk for your iBook system. If they can't supply it (Apple technically doesn't support this model any more) see if they can at least give you the part number so you can try to find one online. Or you will need to buy a retail version of Leopard just make sure you get the copy with CD not DVD as your optical drive will not support the newer dual layer disks. From everyMac: Configured with a slot-loading 8X/24X/16X/24X DVD-ROM/CD-RW "Combo" drive.
The problem you will face here in creating a book disk is the iBook has a PowerPC processor and you will need a PowerPC based system to setup the CD/DVD disk. A newer Intel based system can't setup the disk correctly for your PowerPC system and it will not copy the correct library files as they are different between the different CPU chip architecture (PowerPC & Intel).
If you have a second PowerPC system and have a FireWire cable (400 version) to connect to the other system, you could boot your iBook in Target Mode and then use your other Mac (running Leopard) to install the OS onto your iBook. Just be careful on which drive you select as you don't want to over write your data on your good running Mac.
Follow this Apple TN How to use and troubleshoot FireWire target disk mode.
Lastly, remember this system won't run the newer applications and the system is limited to Leopard (OS-X 10.5.8) and apps that can run under it.
Voeg je antwoord toe
thomas bradshaw zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 38
Altijd: 13,307
