Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor auto's geproduceerd door het Britse Vauxhall, opgericht in 1903.
62 Vragen Bekijk alle
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
Is dit een goede vraag?
Score 2
6 opmerkingen
What year is your Vauxhall?
door
It's a 2005 55 plate
door
Does that relay also control the reversing light?
door
any more my light do not work 1.9 vauxhall combo reg 04
door
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
door
1 commentaar meer tonen
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
information from here
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
That's a great help.
Many thanks.
Geoff
door
You are welcome, best of luck to you.
door
This was really helpful to me many thanks
door
Voeg je antwoord toe
Geoff Heyes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 134
Altijd: 31,775
