Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Vragen Bekijk alle
Why does my iPhone 4s screen show black and blue lines?
My iPhone screen shows only black and blue vertical lines. The screen is not cracked, and still responds to my touch. I've already tried restoring it on iTunes, and I did a hard reset (holding the home and lock button until it turns off and back on).
What parts of the phone do I need to replace to get the display working again?
Is dit een goede vraag?
Score 31
3 opmerkingen
vicky how much will it coast
door
lauren norledge, sorry looks like Vicky hasn't been here since Aug 21,2012. The assembly will cost you anywhere between $35 and $100 depending on where you purchase it from.
door
that still didnt work for me George.... and i need this fixed or my mom will kill me. not literally but yea
door
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
Vicky, your front display consist of multiple pieces. In your case the digitizer (glass) is still intact, but your LCD is no longer working. I suggest that you change the display assembly. Here is the guide for it. The assembly is available right here as well as many other places. Hope this helps, good luck.
iPhone 4S Screen Afbeelding
Product
iPhone 4S Screen
$34.99
Was dit antwoord nuttig?
Score 6
1 Opmerking:
Thank you, I'll replace it as soon as possible :)
door
Try pressing the home and power button at the same time but holding it down until it shows the apple sign. If that doesn't work you can rest your iPhone before sending it back for a replacement.
1- Hold down the home and sleep/wake button at the same time (In order to power off that way)
2- Once you were able to power off, next hold down on the home button and at the same time plug the USB cable into the phone and computer. Keep holding the home button until a message factory settings. It will take a few minutes for it to appear.
3- Once it does click on restore.
mine has done the same thing. im really worried that it might not work anymore. ive already cried today about it. what should i do ~ Aiyana Irving
i need help to and it does not work
Dropped my iPhone today and the screen didn't break, but blue and balck vertical lines show up when i press buttons. I have a lot of important text messages and pictures that i don't want to lose. My phone is still responsive but continues to only show blue and black lines on screen. Very worried and need help!!
1 Opmerking:
plz i have the same issue. how you fixed it ?
door
You should follow the screen repair guide to replace the screen.
Voeg je antwoord toe
Vicky zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 28
Altijd: 197,875
