Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Computer won't turn on
No matter how many times you press the power button, it just won't start.
Out of Power
Your computer just may need to be charged. Plug it into your adapter and make sure your device is plugged into a working outlet.
Damaged Battery
The battery may be damaged. Plug the laptop into the adapter and see if it powers on. If it does, your battery may need to be replaced.
Computer doesn't charge
You plug in the charger but that battery keeps draining.
Wrong/Broken Adapter
You may be using the wrong adapter, or it could be broken. Plug the adapter into a working outlet. If the light on the adapter doesn't light up, your power adapter is broken. In this case, you'll need to purchase a replacement.
Damaged Battery
The battery may be damaged and won't charge. Plug the device into a working charger. If the computer powers on, but the battery doesn't charge you have a broken battery and it may need to be replaced.
Computer is Overheating
The computer heats up while it's being used
Damaged Battery
The computer may be heating up due to it being damaged and not working efficiently. The battery may be damaged if it is the component of the computer causing it to overheat. To fix this issue you may need to replace the battery.
Unclean/Dirty Fan
The computer might be heating up due to dust and dirt clogging up the fan. To fix this issue you need to open up the back of the computer and clean the fan with compressed air. If this does not resolve the issue, you may have to replace the fan.
Sticky/Broken Keys
The keys are stuck, missing, or won't respond.
Sticky Keys
The keys might be sticky due to grime on the keyboard. Take a cotton swab and soak it in rubbing alcohol. Rub the swab around the outsides of the sticky key. Repeat as necessary to remove all the stickiness.
Keys not Responding
The keyboard may be broken. Restart your netbook to see if the problem persists. If it does you may have to replace the key.
Computer Running Slow
Actions take longer to perform than they should
Netbook has been on for too Long
Your netbook may begin to perform poorly if it has not been turned off in awhile. To remedy the problem simply turn off or restart your netbook
Too many Programs Running
Your computer’s performance will decline if you have too many programs running at once. Close out any programs you are not currently using and performance should improve.
Processor is Overheated
A computer’s processor is very energy intensive and is the hottest component of your computer. This problem is especially prevalent in smaller computers. Shut your computer off and check to see if the fan is working properly. If it is not working you may have to add or replace fans.
0 opmerkingen
