Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Device shuts off randomly
The device will shut off at random times while on it
Software conflict
Are there any changes to software or hardware peripherals? If yes then undo or unplug and see if the problem continues.
Faulty Capacitor
A capacitor is the device in the laptop that is used to store an electric charge, This is an important part of your laptop if your laptop is not keeping a charge this may be why your device is turning off
Motherboard
Power up the computer and wait for a short beep. If nothing gets displayed on your monitor and you did not hear a short beep, those could be signs suggestive of a motherboard failure; therefore this could be a reason why your laptop is randomly shutting off.
Keyboard not responding
The keys are not typing anything
Defective keyboard
If you press any key of the keyboard and i it does not work, then you may have a loose connection, you are going to have to gain access to the motherboard for this.
Keys sticking
If keys are failing to come up after you press down you may need to clean your keyboard
Device will not charge
The battery will not charge device or battery dies fast
Faulty battery
Batteries over time will start to decline, due to heat, age and usage. If you have a older model or use your laptop a lot you might want to think about replacing the battery.
Faulty AC adaptor
Confirm that the laptop is receiving AC power,if you connect the laptop to AC power and it does not detect it you need to replace the AC adapter.
Device overheats
The device is exceeding safe temperatures and, or is hot for long periods of time
Heatsink's radiator
Your heatsink's radiator (fan) is probably dusty and thus unable to properly cool your laptop. In order to clean the fan use a can of compressed air.
DVD Blue-Ray player is jammed
Not able to activate DVDS or open or close
Tray will not open
Sometimes the tray will get stuck while CD are within the device, or will not open. To fix this do not force it, for this may break the DVD tray all together.
Drivers are corrupted
Fixing the CD/DVD problems simply involve deleting the filter entries for the third-party device drivers.Some times these can become damaged.
Één opmerking
por favor el numero de parte del integrado de regulacion de voltaje de la tarjeta madre de la laptop toshiba p775-s7320 satellite y su precio pero seria muy amable de enviarme el numero de parte identificado en la tarjeta madre con pu 200
rossi1020 - Antwoord
