Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
The computer repeatedly crashes
When computer is turned on, it randomly crashes.
Software errors and malfunctions
Software errors can be caused by viruses. The best way to fix this problem is to try and remove all viruses and spyware. Do not download any suggested spyware, this can cause your computer to get more viruses. Another reason you software could be malfunctioning is due to unapproved updates. To fix this problem, back up your computer and then restart in safe mode. Continue by undoing the last installation and update. If this doesn't work, reinstall Windows or what ever software your computer has.
Faulty hard drive
Hard drive crashing can be caused by outside elements such as overheating, water damage, or electrical shock.
The screen is discolored and distorted
When computer is turned on, the screen does not exhibit normal colors and flickers.
Computer overheating
Sometimes screen discoloration can be caused by the computer overheating. If you think this is the case, turn computer off and allow computer to cool down.
Required system update
Sometimes the computer just needs to be updated. To check for this issue, go to task manager and see if the screen flickers there. If it does so, the app may need to updated or the display driver replaced. If it does not flicker when task manager is open, the issue is most likely with an app.
Faulty display driver
If the display driver is malfunctioning, the easiest solution is to delete the display driver and download the latest version of it.
The keyboard is sticking/unresponsive
When the keyboard is being used, keys are unresponsive
Keyboard reboot
In many cases the keyboard itself just needs to be rebooted. To check for this problem, click the ‘caps lock’ button and see if the light turns on. If it does not turn on, restart the computer and try again.
Dirty keyboard
A common cause for keys to be unresponsive is if the keyboard itself is dirty or dusty. Use a laptop cleaning kit or a dry toothbrush to gently clean around the individual keys and keyboard. Try using the keys again.
Faulty/broken keys
If there are only a few keys on the keyboard that are unresponsive, you can replace them individually. A key needs to be replaced if it is physically damaged (cracked, water damaged, etc.). Replace keys using this guide.
Faulty/broken keyboard
If the keyboard itself is unresponsive, you may need to replace the whole thing. In order to resolve this problem, you need to purchase the keyboard your computer requires online. Replace the keyboard using this guide.
The fan is not working
After computer has been in use for a while, the fan does not turn on causing the device to overheat.
Dusty fan
The fan may be dusty, causing it to either slow down or stop altogether. An easy solution for this problem is to blow compressed air into the cooling vents on the sides of the laptop. You can either use a can of condensed air or a hairdryer set to ‘cool’ and blow it into the vents.
Faulty fan
If the fan doesn’t turn, there may be an issue with the fan itself. To fix this problem, replace the fan using this guide.
The battery does not hold charge
When the computer is unplugged from the charger, the power depletes very quickly.
Dirty battery
If the battery is losing charge quickly, it may be because the battery is dusty. To fix this problem, you take out the battery and wipe down the battery with a cloth with a little rubbing alcohol. Then put the battery back and try again.
Faulty battery
If the battery will not hold charge, there may be an issue with the battery’s function. The easiest solution to this problem is to replace the battery by taking the old battery out and replacing it with a new battery. You will need to purcahse a new battery for your computer. A link detailing how to find a new battery is located in the Additional Information section on the Toshiba Dynabook TT552-58G wiki.
0 opmerkingen
